Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
RSS discussions
Discussion Discussion forum
Topic Closed.lsp for setting PLs elev. to zero *current entity
 Post Reply Post Reply
Author
ebrody View Drop Down
Groupie
Groupie
Using: AutoCAD Civil 3D 2013
Status: Offline
Direct Link To This Post Topic: .lsp for setting PLs elev. to zero *current entity
    Posted: 08.Oct.2014 at 23:28
(defun C:EZ (); = Current-Entity Elevation to Zero
  (setvar 'Elevation 0.0)
); defun
This doesn't quite do it. To put into words what I'm attempting to accomplish, I'm looking to have my current selection entities set to a zero elevation. It would be alright as well to have to select the entities.
Essentially I don't want to have to open the properties window to set the elevations to zero on two poly lines I'm trying to fillet which is what prompts this issue for me.
Is there a different command/variable I should be using here?
Thanks for any help you can provide.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 09.Oct.2014 at 00:40
You could use the FLATTEN command or do it using the old CHANGE command via the ELEVATION option.
Edited by John Connor - 09.Oct.2014 at 15:03
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 09.Oct.2014 at 14:54
Didn't know about that change command, and that was the ticket. Many thanks. Here's the completed .lsp for anyone else that wants it:
;;  ElevationtoZero.lsp [command names: EZ]
;;  Set Current Entity Elevation to Zero
;;  Ed Brodmarkle, October 8, 2014
(defun C:EZ (/ ss cmde); = Current-Entity Elevation to Zero
  (setq
    ss (cond ((ssget "_I")) ((ssget))); ask User if nothing pre-selected
    cmde (getvar 'cmdecho)
  ); setq
  (if ss
    (progn
      (setvar 'cmdecho 0)
      (sssetfirst nil); clears pre-selection [if any] to avoid object-selection problem
      (command "_change" ss ""
        "_Properties" "_Elev" 0.0 ""
      ); command
      (setvar 'cmdecho cmde)
    ); progn
  ); if
  (C:BYce)
  (princ)
); defun
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 10.Oct.2014 at 15:21
... for which you will need the BYce command, one of my group of ByLayer-related commands in the attached file:
And consider whether, for the sake of the purpose of this thread, to add this line to it:
(setvar 'elevation 0.0)
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 10.Oct.2014 at 17:56
Ah, I didn't see that I left off that modified code bit a little. As you could plainly see it's a modification of your awesome by layer commands.
I tried the setvar 'elevation 0.0 and it didn't work. Not really sure why, but this command as written achieves the thing it needs to do.  Thanks for the help!
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 10.Oct.2014 at 18:02
I just added a command similar to your BYce as a EZce which is the same just injecting that elevation line. Should be aight.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,092 seconds.
