CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 8806
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedDrawing sheet
 Post Reply Post Reply
Author
chrismof View Drop Down
Groupie
Groupie
Using: ACAD 2018
Status: Offline
Direct Link To This Post Topic: Drawing sheet
    Posted: 22.Oct.2016 at 10:01
I have a problem when opening my drawing sheet it appears to have changed to drawing view not sure if I have changed a setting could any please let me know if I can change the setting back to the original.
Thanks
Chris
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 22.Oct.2016 at 12:27
Your description is vague.  Can you be more specific?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: ACAD 2018
Status: Offline
Direct Link To This Post Posted: 22.Oct.2016 at 13:25
Hi John I produced a model (ipt) but when I want to put it into a ISO.dwg I go to Base which opens to a drawing view box this seems to have change from what I normally use  not sure if a setting has changed.
Back to Top
didisu View Drop Down
Newbie
Newbie
Using: Inventor 2017 Pro.
Status: Offline
Direct Link To This Post Posted: 24.Oct.2016 at 03:59
Hi Chris,
I would love to help you but I would request you to sent me a screenshot and ore the drawing file.
Regards
Dietmar
With best regards
Dietmar Schmidt
Back to Top
Groupie
Groupie
Using: ACAD 2018
Status: Offline
Direct Link To This Post Posted: 24.Oct.2016 at 11:53
Hi Dietmar,
Thank you for contacting me I have attached a screen shot of the drawing I think a setting has changed as when I am placing the drawing on the sheet using base a drawing view box comes up which is different to previous.
Best regards
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,572 seconds.
