Czech English Deutsch
Login/Register:
 Visitors: 4211
RSS tips RSS channel - CAD tips
RSS discussion RSS channel - CAD discussion
Discussion Discussion forum
HelpCAD discussion
The information that you provide in this form will make up your forum profile which can be viewed by other forum members. Your email address will only be visible by forum admin and moderators and will be used to send you Forum Notifications. To cancel your account, use the page Opt-out or contact webmaster@cadforum.cz.
How to remove xyz dot within assembly?
 Post Reply Post Reply
Author
tsteffen84 View Drop Down
Newbie
Newbie
Using: Inventor 2016
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote tsteffen84 Quote  Post ReplyReply Direct Link To This Post Topic: How to remove xyz dot within assembly?
    Posted: 30.Nov.2016 at 23:01
Hello all,
I have a xyz with yellow dot appearing on many but not all parts within an assembly. I have tried many ways to turn them off with no success. Anyone out there think they might know how to do this?
Thank you,
Travis
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Connor Quote  Post ReplyReply Direct Link To This Post Posted: 01.Dec.2016 at 12:02
The feature is called a "Connector" which displays as a yellow sphere with an axis triad (the three arrows you see) similar to a user coordinate system.  So what you need to find is the command in Inventor that controls connector visibility and disable it.  Sorry, but I don't use Inventor.
In the model browser if you right-click on one of the joints where the Connector symbol is displayed are you given any options referencing connectors?
Does Configurator 360 ring any bells?
Edited by John Connor - 01.Dec.2016 at 12:09
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,078 seconds.
