CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 6160
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic Closedautocad dwg problem
 Post Reply Post Reply
Author
flock371 View Drop Down
Newbie
Newbie
Using: 2013
Status: Offline
Direct Link To This Post Topic: autocad dwg problem
    Posted: 01.Dec.2016 at 17:04
I was drawing .dwg file during some days, but after bug in my AutoCAD 2015 it showed - Error message when opening or when working in the file. Any help, please, can someone repair dwg image?
A lot of people like to make strange things
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Dec.2016 at 18:00
What was the exact wording of the error message?
Did you try using the RECOVER command?
Well you either solved the problem or gave up and started all over.  In the future you might want to consider using such commands as Overkill, -Purge > Regapps, -Purge > All and Audit to clean up your drawings and fix any errors in the drawing database before saving them.  You'll find that you will have less problems with file corruption.
Edited by John Connor - 01.Dec.2016 at 20:16
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: 2013
Status: Offline
Direct Link To This Post Posted: 06.Dec.2016 at 12:34
I wrote an error message
No I didn't try Recover command, thanks for a tip.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Dec.2016 at 12:52
I don't see where you wrote the contents of the error message.  Did you use invisible lettering?
<<AutoCAD 2015>>
Back to Top
spindly View Drop Down
Newbie
Newbie
Using: CAD2016
Status: Offline
Direct Link To This Post Posted: 06.Dec.2016 at 17:35
You could try and locate your backup file "DrawingName.bak" and change the extension from bak to dwg.
You may get lucky and the backup file could still be usable
Back to Top
Newbie
Newbie
Using: 2013
Status: Offline
Direct Link To This Post Posted: 11.Dec.2016 at 13:12
Error message when opening or when working in the file - that's it
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 12.Dec.2016 at 10:59
What does the error message say specifically?  Jeez, this is like pulling teeth.
Did you try spindly's suggestion?
<<AutoCAD 2015>>
Back to Top
muddassarsaadi View Drop Down
Newbie
Newbie
Using: Autocad Plant 3D 2017
Status: Offline
Direct Link To This Post Posted: 14.Dec.2016 at 13:31
dear Mr #John Connor
i am looking help for North East Coordinates on my isometric DWG on AutoCAD plant 3d 2017
The Problem i am facing is when i generate ISO it is showing East South Coordinates instead of North East Coordinates
can anyone guide me or help how to change this ?
Regards
n tanks in advance
MMS
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Dec.2016 at 13:49
mudd: It is bad form to hijack a thread with a question that does not pertain to it.  Try to remember that in the future.  Thanks.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 14.Dec.2016 at 14:28
i am sorry next time i ll care it
MMS
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,422 seconds.
