Discussion forum
CAD discussion |
FlipFace needed |
Post Reply |
Author | |
opacheco
Newbie Joined: 16.Nov.2009 Location: Honduras Status: Offline Points: 2 |
Topic: FlipFace needed Posted: 01.Feb.2017 at 02:07 |
Hi,
I would like to know if does exit a similar LISP routine to Flipface.lsp but for Polylines and 3Dpolylines in order to flip its contour direction(clokwise to counter clockwise and viseversa ???....I am drawing for a auditorium Acoustic Design but when I use MIRROR command in AutoCad 2015, this change the initial direction of the curve using polyline: this is a serious problem in the acoustics software that I use for. I can do this one by one in the Acoustic app but there are many surfaces (closed curves defined by 2D polylines and 3Dpolylinee only!), 8,000 aprox.!....and I am searching for a LSP routine in order to do ALL this work at once!!. Any comments will be appreciate! opacheco.
Thanks a lot for help!
Vladimir Michl
Posted: 01.Feb.2017 at 12:00 |
FlipFace (for faces) is available on the Download page. For polylines you can use the REVERSE command in AutoCAD.
Vladimir Michl (moderator)
Post Reply | |
Tweet
This page was generated in 0,594 seconds.
