CZ | EN | DE
Login or
registration
  Visitors: 4816
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedDraftSight - Entity tracking line disappeared
 Post Reply Post Reply
Author
MN-rjo View Drop Down
Newbie
Newbie
Using: Draftsight
Status: Offline
Direct Link To This Post Topic: DraftSight - Entity tracking line disappeared
    Posted: 14.Mar.2017 at 15:07
In DraftSight, something weird has happened to my settings. Probably it is just a matter of selecting/deselecting a check mark somewhere. Anyhow, this is really annoying me.
When drawing any figure with Esnap (F3) and Etrack (F11) switched on and with Ortho (F8) switched off, I get a horizontal/vertical tracking line every time I move the pointer to a midpoint, endpoint etc., for instance when drawing a standard rectangle. But if I do with Ortho switched on, the tracking line never pops up.
Can anyone tell me how to make this tracking line pop up regardless of the Ortho function being switched on or off?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Mar.2017 at 16:01
If orthomode is enabled why would you need a tracking line to draw a line up, down, left or right?  You're basically locked in.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Draftsight
Status: Offline
Direct Link To This Post Posted: 14.Mar.2017 at 17:24
I need an entity tracking line with ortho ON because the line which I am actually drawing has to point exactly in direction 0, 90, 180 or 270 degr.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Mar.2017 at 10:06
Maybe I'm not following you here but doesn't having orthomode enabled practically guarantee that lines can be drawn at 0, 90, 180 and 270 degrees?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Draftsight
Status: Offline
Direct Link To This Post Posted: 15.Mar.2017 at 11:18
Yes it does but if I want to make my line stop in a position perpendicular to a certain point, then I can't make use of a tracking line due to the fact that it simply doesn't appear when ortho is on (it did in the past). If I switch off ortho, the tracking line will however appear - but then the line I am actually drawing is no longer pointing in direction 0, 90, 180 or 270 degrees Confused
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Mar.2017 at 11:22
Then it stands to reason it is a tracking line setting.  Have you checked?
Have you also posted your question in the Draftsight forum (at their website)?
Edited by John Connor - 15.Mar.2017 at 11:25
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Draftsight
Status: Offline
Direct Link To This Post Posted: 15.Mar.2017 at 11:49
I am unable to find any tracking line settings in Options.
No, my inquiry has not yet been posted on any other forum than this.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Mar.2017 at 11:57
I don't have access to my copy of Draftsight at the moment so I am unable to test the functionality of the features you have mentioned.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Draftsight
Status: Offline
Direct Link To This Post Posted: 15.Mar.2017 at 16:45
I managed to solve it Smile
Apparently, "Parallel" has to be unticked in Options -> User Preferences -> Drafting Options -> Pointer Control -> EntitySnaps. Still puzzled though how this box was unticked in the first place. Anyway, it works now.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Mar.2017 at 18:00
Your perseverance is commendable.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,434 seconds.
