CZ | EN | DE
Login or
registration
  Visitors: 11416
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedLinetype Issues
 Post Reply Post Reply Page  123>
Author
mik29 View Drop Down
Newbie
Newbie
Using: AutoCAD 2016
Status: Offline
Direct Link To This Post Topic: Linetype Issues
    Posted: 15.Mar.2017 at 17:06
Hello.
I am working in C3D 2016. I noticed my linetypes were not correct. Our State DOT has standards for linetypes. After I did imported the standards and open the drawing I had some strange lines. I have my LTSCALE =1. MSLTSCALE=1, VSLTSCALE=1 and it has not changed. The biggest problem that only my computer have this issue. I attached pictures of what they look on my computer and on others.
Thank you
Back to Top
aanonimnim View Drop Down
Newbie
Newbie
Using: autocad
Status: Offline
Direct Link To This Post Posted: 05.Apr.2017 at 01:07
Hi,
Is it a line or polyline?
Check the thickness of the layer as well. Sometimes the same layers have different standard settings. I know - sound obvious but I catch myself many times on that ;)
Kamil
www.CADMasters.guru
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Apr.2017 at 11:34
aa: Please explain something to me.  If I give you a drawing where I have set the lineWEIGHT by layer and you open that drawing on your computer why/how would it appear differently unless you changed it or you had lineweight display enabled/disabled?  Additionally, if it is a pline the system variable PLINEWID is saved with the drawing and not in the Windows Registry.  How then does it automagically change when opened by another cad tech on a different computer?
Edited by John Connor - 05.Apr.2017 at 12:52
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Apr.2017 at 12:07
mik29: What is VSLTSCALE?  When I type that in at the command line I get this:
Command: VSLTSCALE
Unknown command "VSLTSCALE".  Press F1 for help.
Could you have been referring to PSLTSCALE?
BTW...is Lineweight Display enabled?
Edited by John Connor - 05.Apr.2017 at 12:51
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD 2016
Status: Offline
Direct Link To This Post Posted: 05.Apr.2017 at 15:26
this is what we're wondering too. Thanks.
Back to Top
Newbie
Newbie
Using: AutoCAD 2016
Status: Offline
Direct Link To This Post Posted: 05.Apr.2017 at 15:30
sorry I mistype. It is PSLTSCALE .Yes Linewight display is enabled.
Thank you.
Back to Top
Newbie
Newbie
Using: AutoCAD 2016
Status: Offline
Direct Link To This Post Posted: 05.Apr.2017 at 15:34
Hello.
It's PLINE.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Apr.2017 at 15:43
So what happens if you toggle Lineweight off?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD 2016
Status: Offline
Direct Link To This Post Posted: 05.Apr.2017 at 15:52
Absolutely no changes.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Apr.2017 at 16:30
Do you utilize custom lisp routines that automatically load?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,563 seconds.
