Discussion forum
CAD discussion |
Teaching Computer Programming to Kindergartners (Part 3) |
Post Reply |
Author | |
AliveInTheLab
RSS robots Joined: 20.Nov.2009 Status: Offline Points: 425 |
Topic: Teaching Computer Programming to Kindergartners (Part 3) Posted: 26.Apr.2017 at 04:00 |
In previous blog articles, I talked about using Kodable to teach kindergarten students how to computer program — eventually to write JavaScript: Kodable is coding for kids with measurable student outcomes. The Kodable K-5 standards are a roadmap for developing the whole student through computer science. Their goal is to reach all students and see computer science become part of a complete elementary education. The first lesson was based on sequence. Programmers need to tell what computers what to do in the correct order. If one of your computer program statements is not in the right order, the computer program will not produce the correct result. The students learn that by placing directional arrows in the right order so that their Fuzzball (fictional character) traverses a path and picks up coins. The second lesson was based on conditionals. Conditionals often appear in computer programs as "if" statements. To illustrate the concept to students, the students drag and drop a colored square onto the command sequence to indicate "if my Fuzzball comes to a square that matches the color, take the action indicated by the directional arrow. Understanding how checking a condition before taking an action leads students to write correct computer programs. Though normally reserved for 1st grade, loops are the third topic. Computer programmers use loops when they want the computer to execute a sequence of instructions more than once. Rather than repeat the instructions for each use, they encase them in a loop that executes multiple times. This saves computer memory as the instructions already in memory are re-executed rather than loading those same instructions into more memory. Loops are circles: We see them every day in toys and amusement rides: In the case of Kodable, a loop is represented by a set of purple brackets. The students indicate which directions that they want their Fuzzball to move and indicate how many times to perform the loop. Here is a simple example: To move the Fuzzball along the path, you'll notice that the moves are forward, down, forward, down, forward, down, and forward. That's "forward, down" 3 times followed by another forward to finish it off. In JavaScript pseudo-code, a correct solution would be: The kindergarten students don't work with code. Instead, they drag and drop loop brackets and arrows. So for the students, a correction solution looks like this: You can see that the logic is there even though the programming language is a collection of arrows instead of a collection of JavaScript statements. The 3 indicates that the instructions in the loop are to be performed three times. The instructions are forward and down as indicated by the directions of the arrows. The loop is followed by one more forward instruction to get the blue Fuzzball all the way across the path. Education is alive in the lab. Go to the original post... |
It's Alive in ihe Lab - Autodesk Labs blog by Scott Sheppard
Post Reply | |
Tweet
This page was generated in 0,449 seconds.
