Please abide by the
rules of this forum.
Author |
Topic Search Topic Options
Datumarch
Newbie
Using: Autocad 2013
Status: Offline
Topic: Converting text Posted: 08.Sep.2017 at 16:43 |
I have a client logo which is a block, that includes a specific text style. When moving computers the text style changes to a default. What I would like to do is just turn the text into some sort of object so that it has no text properties and will not change from computer to computer. Any ideas?? -- Thanks Eric
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 08.Sep.2017 at 16:56 |
Then aren't you talking about an image file (.jpg or .png)?
<<AutoCAD 2015>>
Datumarch
Newbie
Using: Autocad 2013
Status: Offline
Posted: 08.Sep.2017 at 17:07 |
No, unfortunately the logo was build in cad. So it has mtext in the block of the logo. Now when we use it between computers and new vs old software, it changes the text style. I would just like the logo to all be one, non editable logo with no ability to edit the text or have it automatically change between computers. -- Thanks
Eric
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 09.Sep.2017 at 14:08 |
Trace the damn thing then turn it into a block. Done.
<<AutoCAD 2015>>
scj.schulz
Groupie
Status: Offline
Posted: 09.Sep.2017 at 15:56 |
You can use a DXB-Plotter for this. Perhaps you first have to configure this DXB-Plotter using the PLOTTERMANAGER-command. Plot the logo into a file, use the DXBIN-command to insert the created DXB-file in a new drawing and so all letters and drawing entities are converted into single lines. Hope this helps Regards Jochen
www.ant-ares.de
Edited by scj.schulz - 09.Sep.2017 at 15:58
Kent Cooper
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Posted: 11.Sep.2017 at 20:40 |
In your Printer/Plotter Name: list in the Plot dialog box, there should be some choices that will make a PDF or PNG or JPG. Isolate the part of their logo Block that you want to do this with, "plot" it by itself to one of those kinds of files, and in BEDIT or REFEDIT, erase the original from the Block and use IMAGEATTACH to bring in the PDF/PNG/JPG version.
Nate143
Newbie
Using: AutoCAD 2018, Revit 2018, Inventor 2018
Status: Offline
Posted: 12.Sep.2017 at 11:38 |
From the Autodesk Website
The following method only works with text that uses SHX fonts. If your text objects use True Type fonts (TTF), you must first assign a comparable SHX font to the text objects you wish to explode. Then:- Issue the command WMFOUT.
- Specify a file name and location for the WMF file and click Save.
- Select the text objects you wish to explode and press ENTER.
- Issue the command WMFIN.
- Choose the WMF file created in steps 1-3 and click Open.
- Specify an insertion point.
- Specify an insertion scale. Typically, a scale factor of 2 is required to get the object to be the same size as the original.
- Specify rotation (usually 0).
- The inserted object is a block, so EXPLODE it.
- The text is now reduced to polylines.
Otherwise, use the trace option
Regards Nate
philippe JOSEPH
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Posted: 13.Sep.2017 at 14:32 |
Hello Nate143, your method is too good to be true and it works so goooooooooooood ! I do have to convert texts from AutoCAD to Solidworks or Pro Engineer and when I want to text be kept on theses softwares I "write" 3D text of my own, this will be too good, although I have already created from blank letters, capital letters, numbers and various other text in 3D solids.
Nate143
Newbie
Status: Offline
Posted: 13.Sep.2017 at 15:41 |
Only a pleasure
Regards
Nate...
