Please abide by the
rules of this forum.
Units of the Layout
Author
Topic Search Topic Options
Dariusddd
Newbie
Using: Autocad2015
Status: Offline
Topic: Units of the Layout Posted: 23.Sep.2017 at 15:33
Hi all,
< id="SL_locer" ="" title="Lock-in "> < value="auto">Detect language< value="af">Afrikaans< value="sq">Albanian< value="ar">Arabic< value="hy">Armenian< value="az">Azerbaijani< value="eu">Basque< value="be">Belarusian< value="bn">Bengali< value="bs">Bosnian< value="bg">Bulgarian< value="ca">Catalan< value="ceb">Cebuano< value="ny">Chichewa< value="zh-CN">Chinese (Simplified)< value="zh-TW">Chinese (Traditional)< value="hr">Croatian< value="cs">Czech< value="da">Danish< value="nl">Dutch< value="en">English< value="eo">Esperanto< value="et">Estonian< value="tl">Filipino< value="fi">Finnish< value="fr">French< value="gl">Galician< value="ka">Georgian< value="de">German< value="el">Greek< value="gu">Gujarati< value="ht">Haitian Creole< value="ha">Hausa< value="iw">Hebrew< value="hi">Hindi< value="hmn">Hmong< value="hu">Hungarian< value="is">Icelandic< value="ig">Igbo< value="id">Indonesian< value="ga">Irish< value="it">Italian< value="ja">Japanese< value="jw">Javanese< value="kn">Kannada< value="kk">Kazakh< value="km">Khmer< value="ko">Korean< value="lo">Lao< value="la">Latin< value="lv">Latvian< value="lt">Lithuanian< value="mk">Macedonian< value="mg">Malagasy< value="ms">Malay< value="ml">Malayalam< value="mt">Maltese< value="mi">Maori< value="mr">Marathi< value="mn">Mongolian< value="my">Myanmar (Burmese)< value="ne">Nepali< value="no">Norwegian< value="fa">Persian< value="pl">Polish< value="pt">Portuguese< value="pa">Punjabi< value="ro">Romanian< value="ru">Russian< value="sr">Serbian< value="st">Sesotho< value="si">Sinhala< value="sk">Slovak< value="sl">Slovenian< value="so">Somali< value="es">Spanish< value="su">Sundanese< value="sw">Swahili< value="sv">Swedish< value="tg">Tajik< value="ta">Tamil< value="te">Telugu< value="th">Thai< value="tr">Turkish< value="uk">Ukrainian< value="ur">Urdu< value="uz">Uzbek< value="vi">Vietnamese< value="cy">Welsh< value="yi">Yiddish< value="yo">Yoruba< value="zu">Zulu
< value="af">Afrikaans< value="sq">Albanian< value="ar">Arabic< value="hy">Armenian< value="az">Azerbaijani< value="eu">Basque< value="be">Belarusian< value="bn">Bengali< value="bs">Bosnian< value="bg">Bulgarian< value="ca">Catalan< value="ceb">Cebuano< value="ny">Chichewa< value="zh-CN">Chinese (Simplified)< value="zh-TW">Chinese (Traditional)< value="hr">Croatian< value="cs">Czech< value="da">Danish< value="nl">Dutch< value="en">English< value="eo">Esperanto< value="et">Estonian< value="tl">Filipino< value="fi">Finnish< value="fr">French< value="gl">Galician< value="ka">Georgian< value="de">German< value="el">Greek< value="gu">Gujarati< value="ht">Haitian Creole< value="ha">Hausa< value="iw">Hebrew< value="hi">Hindi< value="hmn">Hmong< value="hu">Hungarian< value="is">Icelandic< value="ig">Igbo< value="id">Indonesian< value="ga">Irish< value="it">Italian< value="ja">Japanese< value="jw">Javanese< value="kn">Kannada< value="kk">Kazakh< value="km">Khmer< value="ko">Korean< value="lo">Lao< value="la">Latin< value="lv">Latvian< ed="ed" value="lt">Lithuanian< value="mk">Macedonian< value="mg">Malagasy< value="ms">Malay< value="ml">Malayalam< value="mt">Maltese< value="mi">Maori< value="mr">Marathi< value="mn">Mongolian< value="my">Myanmar (Burmese)< value="ne">Nepali< value="no">Norwegian< value="fa">Persian< value="pl">Polish< value="pt">Portuguese< value="pa">Punjabi< value="ro">Romanian< value="ru">Russian< value="sr">Serbian< value="st">Sesotho< value="si">Sinhala< value="sk">Slovak< value="sl">Slovenian< value="so">Somali< value="es">Spanish< value="su">Sundanese< value="sw">Swahili< value="sv">Swedish< value="tg">Tajik< value="ta">Tamil< value="te">Telugu< value="th">Thai< value="tr">Turkish< value="uk">Ukrainian< value="ur">Urdu< value="uz">Uzbek< value="vi">Vietnamese< value="cy">Welsh< value="yi">Yiddish< value="yo">Yoruba< value="zu">Zulu
Text-to-speech function is limited to 200 characters
I have working on file which is SavedAs from other file, maybe not genuine AutoCAD's file. I come to Layout modeling stage. I choose A1 paper size. Setup manager shows 840x594 mm. Thats OK. But in Paper view I decide to measure paper size. Ant it shows me 32x23. It is in inches if I'm right. Dimscale is OK. Units are decimal...
The question - where is the problem and how to return it back to Metric world?
thank you
Darius
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 24.Sep.2017 at 13:46
The problem most likely is that you opened the default drawing template file named acad.dwt (imperial units) rather than the one named acadiso.dwt (metric) or a similar metric drawing template. Try again.
"Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance." <<AutoCAD 2015>>
Forum Jump
-- Select Forum --
-CAD Forum- (read-only)
AutoCAD
Inventor
Revit
AutoCAD Civil 3D, Map
Fusion 360
3ds Max, Maya
CAD - general
Arkance (CAD Studio) applications
RSS Feeds
Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum
This page was generated in 0,408 seconds.
