Discussion forum
CAD discussion |
Hot to connect these two solid |
Post Reply | Page <12 |
Author | |
rdjavi
Newbie Joined: 30.Jan.2014 Location: Bosnia Hercegovina Using: AutoCAD2014 Status: Offline Points: 12 |
Posted: 06.Oct.2017 at 15:33 |
I just need to convert the surface in solid to have a one solid object instead of multiple surfaces. I export the 3D model in IGS file and work with him in another software.
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 06.Oct.2017 at 17:11 |
So pick a method and try it. If it doesn't work try another method.
1. Convert to solid. 2. Thicken then convert to solid. 3. SurfSculpt (must be watertight).
<<AutoCAD 2015>> |
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 616 |
Posted: 06.Oct.2017 at 20:11 |
Images and drawing files here.
[Including the "Hot" in place of "How" in the Subject line -- it's good to be eager about these things.]
Edited by Kent Cooper - 06.Oct.2017 at 20:13 |
Tweet
This page was generated in 0,660 seconds.
