Discussion forum
CAD discussion |
autocad |
Post Reply | Page 123 4> |
Author | |
shwetakakran
Newbie Joined: 05.Feb.2018 Location: India Using: AutoCAD2013 Status: Offline Points: 2 |
Topic: autocad Posted: 17.Feb.2018 at 10:38 |
Dimstyle can be accessed via the Ribbon after this you have to clicking on the Annotate tab and looking at the Dimensions panel.
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 20.Dec.2017 at 14:40 |
If you suspect a corrupted font or that it is the wrong version then the best I can offer is to provide you with a copy of the font I have on my computer. You will have to follow the Microsoft procedures for removing and installing a font as outlined here...
https://support.microsoft.com/en-us/help/314960/how-to-install-or-remove-a-font-in-windows |
<<AutoCAD 2015>> |
John Connor
Posted: 20.Dec.2017 at 14:03 |
Are you sure you are specifying the correct font? Did you substitute the font for the Style called Standard or create a new dimension style?
Let's see a screenshot of your Style dialog box and your DimStyle > Text tab dialog box. The only other thing I can think of is that your copy of Technic is either corrupt or the wrong version. Technic is not an AutoCAD .shx font. It is a Windows Truetype font. Here are the details: Edited by John Connor - 20.Dec.2017 at 14:09 |
<<AutoCAD 2015>> |
marox
Newbie Joined: 20.Dec.2017 Location: Lithuania Using: AutoCAD2016 Status: Offline Points: 9 |
Posted: 20.Dec.2017 at 13:58 |
John Connor
Posted: 20.Dec.2017 at 13:51 |
Open the attached drawing. Do the diameter symbols display both in the dimension and in the plain text entities?
The drawing was saved in 2010 file format so you should be able to open it. uploads/165260/Technic_test.dwg |
<<AutoCAD 2015>> |
John Connor
Posted: 20.Dec.2017 at 13:48 |
There are no spaces between those three characters. It is %%c not %% c. Got it?
<<AutoCAD 2015>> |
marox
Posted: 20.Dec.2017 at 13:40 |
I'm doing well, but the program is doing wrong. %% c does not help
John Connor
Posted: 20.Dec.2017 at 13:27 |
Then you are doing something wrong. The diameter symbol can be reproduced using the Technic font.
Try entering it manually using %%c. |
<<AutoCAD 2015>> |
marox
Posted: 20.Dec.2017 at 13:19 |
so the same problem
John Connor
Posted: 20.Dec.2017 at 13:16 |
I did not ask for a video. I asked you to run a simple test by creating a new drawing to see if the problem is repeated. It would take less than a minute to do.
Edited by John Connor - 20.Dec.2017 at 13:16 |
<<AutoCAD 2015>> |
Tweet
This page was generated in 0,381 seconds.
