Discussion forum
CAD discussion |
Revit vs Archi CAD |
Post Reply |
Author | |
Bdzelka
Newbie Joined: 20.Nov.2017 Location: Estonia Using: Solidworks2015, ArchiCAD 20, 3ds MAX 2016 Status: Offline Points: 10 |
Topic: Revit vs Archi CAD Posted: 21.Nov.2017 at 09:48 |
As it's written in my profile I use ArchiCAD. But I see that lots of you use Revit for the same purpose (architecture design).
Are there any advantages of Revit? Edited by Bdzelka - 21.Nov.2017 at 13:43 |
Vladimir Michl
Posted: 21.Nov.2017 at 09:50 |
Sure - more users, more add-ons and attached workflows, easier libraries, adaptivity, Dynamo visual programming...
Vladimir Michl (moderator)
noobong
Newbie Joined: 20.Oct.2016 Location: United Arab Emirates Using: autocad2016 Status: Offline Points: 10 |
Posted: 22.Jan.2018 at 13:42 |
FOR ME REVIT MANY USER HERE IN M.E. USING REVIT RATHER THAN ARCHICAD..
rayvatengg
Newbie Joined: 30.Jan.2018 Location: United States Using: AutoCAD, Revit, 3Ds Max, Autodesk Status: Offline Points: 1 |
Posted: 30.Jan.2018 at 13:08 |
Revit is Autodesk's 4D building data demonstrating programming. This capable instrument utilizes a clever model-based procedure to help design all parts of a building venture, from outline through to development and past. While Revit is a fabulous instrument for planners, its degree is immense and its tool compartment is profound - it likewise benefits engineers, manufacturers, venture chiefs and that's only the tip of the iceberg. ArchiCAD is a BIM programming delivered by Graphisoft and intended for indistinguishable purposes from Revit. There's no preventing that both from claiming these CAD alternatives are effective devices, and as usual, devoted clients of each will normally think their inclination is better. Revit Advantages: immense request in the market, solid improvement stage, broadly upheld by courses and instructional exercises, more noteworthy coordination and joint effort. It is implied for design, yet additionally for structure and MEP. Revit Disadvantages are: it doesn't keep running on OSX, just incompletely multi-strung (so it needs the quickest CPU), document size and adaptability issues. Ar iCAD`s preferences and inconveniences It is a 3D Modeling and CAD application which enables you to draw, model and show building outlines essentially and rapidly. ArchiCAD is protest situated, which implies that it will empower you to create and alter three-dimensional questions and deliver 2D structural illustrations and 3D models of structures. ArchiCAD Advantages are: completely multi-strung, runs additionally on OSX, has a friendlier UI and is arranged towards designers. It has an extremely very much created help for IFC, great drafting, format approach and not too bad rendering. Likewise, it has exceptionally adaptable and proficient parametric articles (GDL objects don`t influence record estimate). ArchiCAD Disadvantages are: custom articles require GDL scripting, numerous old workarounds are never completely fathomed, a few expansions are never legitimately refreshed and less-utilized API.
https://www.rayvatengineering.com - 3D Rendering Studio
Post Reply | |
Tweet
This page was generated in 0,355 seconds.
