Czech English Deutsch
Login/Register:
 Visitors: 4230
RSS tips RSS channel - CAD tips
RSS discussion RSS channel - CAD discussion
Discussion Discussion forum
HelpCAD discussion
Hatch Creation Help
 Post Reply Post Reply
Author
martingtc View Drop Down
Newbie
Newbie
Using: 2008LT
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote martingtc Quote  Post ReplyReply Direct Link To This Post Topic: Hatch Creation Help
    Posted: 21.Dec.2017 at 16:52
Can someone please help me? I've drawn a 1m x 1m square and need the hatch inside as a .pat but I just can't work it out :( can someone help?
Back to Top
Breeze104 View Drop Down
Senior Member
Senior Member
Using: Production Design Suite Premium 2015
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Breeze104 Quote  Post ReplyReply Direct Link To This Post Posted: 21.Dec.2017 at 17:13
Can you upload a screen shot of what "you" are getting?  Because when I opened the dwg it was total hatched.
Breeze
Just another Brick In The Wall day
Back to Top
Newbie
Newbie
Using: 2008LT
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote martingtc Quote  Post ReplyReply Direct Link To This Post Posted: 21.Dec.2017 at 17:59
Sorry, that's how I want the hatch to look - a diamond pattern with thick bars. I've drawn the end product but need a hatch for it please
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Connor Quote  Post ReplyReply Direct Link To This Post Posted: 21.Dec.2017 at 18:07
So you want someone here to create a custom hatch pattern.  What are you willing to pay?
Edited by John Connor - 21.Dec.2017 at 18:21
<<AutoCAD 2015>>
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD, Architectural Desktop
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kent Cooper Quote  Post ReplyReply Direct Link To This Post Posted: 21.Dec.2017 at 20:37
I happen to have one quite similar to that:
*LATT60,LATTICE-WORK AT 60 DEGREES, 1" SLATS, 3" GAPS
60,0,0,0,4
60,1.1547,0,0,4
120,0,0,2.3094,4,3.4641,-1.1547
120,1.1547,0,2.3094,4,-1.1547,3.4641
Are you capable of figuring out how to alter that for your size and proportions?
Also, you will need to decide whether the 70x120 diamond dimensions are the critical thing, or an actual 60-degree angle is wanted [yours is only about 1/4 of a degree off of 60].  If the former, the angle designators above will have to be changed as well as the offsets and pen-down/pen-up numbers.  If the latter, the angles above are good.
Back to Top
Newbie
Newbie
Using: 2008LT
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote martingtc Quote  Post ReplyReply Direct Link To This Post Posted: 22.Dec.2017 at 09:15
Pefect!! that's awesome. I have another which is the same, but 100 across and 170 top to bottom. Which valus would I change on the txt file?
Thank you
Edit: actually, it's a bit off - the bars are 20 when they need to be 32 :(
Edited by martingtc - 22.Dec.2017 at 11:38
Back to Top
Senior Member
Senior Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kent Cooper Quote  Post ReplyReply Direct Link To This Post Posted: 22.Dec.2017 at 15:41
You can make your own, at whatever sizes and/or proportions and/or angles you want.  Read about it in Help [>>here<< for 2018, but no different for earlier versions], draw up your specifics in a limited area, and use the image for what values to put where in the pattern definitions.
Edited by Kent Cooper - 22.Dec.2017 at 15:45
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,078 seconds.
