CZ | EN | DE
Login or
registration
  Visitors: 7056
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedChange Object or line back UCS to WCS
 Post Reply Post Reply
Author
zyborgmonkey View Drop Down
Newbie
Newbie
Using: Autocad
Status: Offline
Direct Link To This Post Topic: Change Object or line back UCS to WCS
    Posted: 28.Dec.2017 at 12:11
SOLVED
So I've been working on some drawings where I've needed to align the ucs to the subject to draw on the correct plane.
I don't tend to use the dynamic ucs because as all the lines are real life surveyed .. nothing is perfectly straight or on the same plane so this tends to give bad results and is just a pain.
The issue I now face is that going back to WCS I find that a lot of objects have different z values tied to various UCS rather than WCS. IE if you change the z value manually in properties or use FLATTEN in some cases the line will shoot off in the XY WCS direction.
I think the problem is caused by using polylines within the UCS as they are flat lines that only run along one elevation/Z and whatever blah blah programming,database etc etc it just doesn't work. So using things like FLATTEN can destroy your drawings (as I've been reminded of recently before saving a good backup -_-) I'm guessing this may be one of the reasons .
aaanyway I struggled to find an answer or the topic so thought I'd post this in case anyone else needs help
SOLUTION
BURST your blocks (to keep any ATTDEF info) and EXPLODE all of your 2d polylines  before using the FLATTEN command or touching the Z values.
and only ever use flatten on drawings you know were drawn completely in WCS or that don't contain 2dpolys.
Back to Top
adam007 View Drop Down
Newbie
Newbie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Posted: 29.Dec.2017 at 17:38
Thank you for that, I was searching for this answer too.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 29.Dec.2017 at 17:41
I kind of doubt that.  Seems rather suspicious.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,387 seconds.
