Discussion forum
CAD discussion |
How to Create Dimension Like This? |
Post Reply |
Author | |
dery
Senior Member Joined: 31.Jan.2018 Location: United States Using: AutoCAD 2014 Status: Offline Points: 111 |
Topic: How to Create Dimension Like This? Posted: 31.Jan.2018 at 04:22 |
Can someone please tell me how to create a dimension like this in AutoCAD? Thank you.
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1426 |
Posted: 31.Jan.2018 at 08:21 |
Hello dery, the "dimensions" indicated by the red ? are not dimensions but texts that you can create with the command LEADER.
For the rest of the dimensions it depends if you are doing the job in 2D or 3D. 2D is isometric drawing with its specificities, 3D is real 3D work with its specificities ( you have to be motivated to place dimensions in the model space, ask for it eventually ).
dery
Posted: 31.Jan.2018 at 08:38 |
I tried the LEADER command but there is no arrow. How to make the LEADER with arrow?
philippe JOSEPH
Posted: 31.Jan.2018 at 11:19 |
Hello again dery, the arrow should be in the options that you can set.
Launch the command but don't do the first clic, take a look at the command line to type P for parameters ( or an other letter because my AutoCAD is in French ). You may have no arrow if the text is too close to the first clic or if you use a non calibrated dimension style.
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 31.Jan.2018 at 12:21 |
As far as I can tell there is no Parameter option for the LEADER command in plain AutoCAD. As a matter of fact there are no options at all. If you want options you have to use the MLEADER command.
Use the MLEADER command to create multiple leaders from the same annotation. One more thing....note that some of the annotation pictured above is NOT isometric. And lastly, if you really want to get technical about it you could even create/use isometric arrowheads. Edited by John Connor - 31.Jan.2018 at 12:24 |
<<AutoCAD 2015>> |
philippe JOSEPH
Posted: 31.Jan.2018 at 13:16 |
Hello John, sorry for the LEADER instead of MLEADER, my AutoCAD is in French.
I'm interested with the isometric arrowheads.
John Connor
Posted: 31.Jan.2018 at 14:13 |
Re: arrowheads.
Users would have to make their own oblique arrowhead blocks and substitute them for the default arrowheads AutoCAD normally uses in dimensioning a drawing. |
<<AutoCAD 2015>> |
philippe JOSEPH
Posted: 31.Jan.2018 at 14:22 |
I have uploaded in the CAD/BIM Blocks library my 3D file : VIBRATOR ARM.dwg
I have placed here 3D dimensions that have to be placed after setting different UCS. Dery ( and John ), ask for more if necessary. I suppose that this is a home work.
John Connor
Posted: 31.Jan.2018 at 14:30 |
I wasn't looking for a drawing. If I need a single line isometric piping drawing I do it in 3D. If I need something like what the OP has pictured above I do that, including the dimensioning, in 3D as well.
<<AutoCAD 2015>> |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 02.Feb.2018 at 13:37 |
MLEADER is definitely the right command for this. It uses arrows by default. Please note that you can use it to "dimension" 3D objects but the leader itself will be 2D (in the current UCS plane). So make sure you first create a UCS as required - e.g. UCS View.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
Post Reply | |
Tweet
This page was generated in 0,344 seconds.
