CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 17675
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedXref Layer Management Routine
 Post Reply Post Reply
Author
giwplay1 View Drop Down
Newbie
Newbie
Using: Acad 2015, Acad C3D2015
Status: Offline
Direct Link To This Post Topic: Xref Layer Management Routine
    Posted: 15.May.2018 at 18:55
I am searching for a lisp routine that manages xref layers without the need to open the xref.  My prior company had a routine in which when executing it and picking an entity within the xref (let's say for example a contour line), it would pull up a dialogue box that would provide varying tools (ie, changing the color, linetype, etc), but most importantly, would allow you to freeze the layer, but more so, going deeper or shallower, depending on whether the xref was an overlay or attached.  Currently, if I freeze a layer in the xref, sometimes it freezes other layers that I want to remain on.  Does this make sense?
G. Ira Wallace, PE, QSD/QSP
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,316 seconds.
