Discussion forum
CAD discussion |
Faster way of formatting text to particular format |
Post Reply |
Author | |
z1990m
Newbie Joined: 03.May.2017 Location: United Kingdom Using: AutoCAD 2014 Status: Offline Points: 12 |
Topic: Faster way of formatting text to particular format Posted: 25.May.2018 at 22:46 |
Hi,
This is probably trivial for most people but I’m strugging to invent a work around for lots of typing and mouse clicks. What I have is a survey drawing unedited with multiple text displaying depths in the format of “0.00d” However the survey software spits out these filths in all different formats e.g. “.0” “0.0” “.00” What I currently do as my fastest way to rectify this is do multiple QSELECT commands each time using wildcards like #.# or .# and using a lisp command that I found on the net to add prefixes and suffixes in order to format all the text to read “#.##d” What I originally thought was to record a macro of me running all of these QSELECT commands and save that, problem being it grinds to a halt once the QSELECT dialog box gets involved. Hopefully that made sense to someone, and if someone could help it would save me so much time. Thanks |
Many Thanks
Zak |
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 616 |
Posted: 30.May.2018 at 15:17 |
Do all of them always end with a "d" and never have any other content except the decimal-numerical part? If so, it shouldn't be hard to make a routine that would "fix" such text content.
Edited by Kent Cooper - 30.May.2018 at 15:18 |
z1990m
Posted: 30.May.2018 at 19:01 |
Kent,
To be honest, no they don’t as I could use the lisp I have to add the “d” (depth in case you where wondering) as a suffix at the end. Mainly just trying to speed up my prep time before finalising my drawings as the survey software we use spits out some less than ideal formats for this text. If you could help then it would be very much appreciated! ?? Zak |
Many Thanks
Zak |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2015 |
Posted: 03.Jun.2018 at 08:24 |
I think it should be possible to use srxText (a general text replacement utility, see Download) and find a regular expression which would cover all wrong formats, and replace it then with the right one. If you send me a list of all possible wrong formats, I can help to code such expression.
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
bigdave34
Newbie Joined: 27.Jun.2013 Location: United Kingdom Using: autodcad 2014 Status: Offline Points: 1 |
Posted: 18.Jul.2018 at 14:35 |
Hi wondering if you can help me using srxtext command?
I want to replace a KKS code prefix, the code is alphanumeric so currently something like 3HAD10#### is the start can be any combination of letters though, just want to change the 3 to 1. Any ideas? Thanks
Edited by bigdave34 - 18.Jul.2018 at 14:36 |
Post Reply | |
Tweet
This page was generated in 0,334 seconds.
