CAD Forum - Database of tips, tricks and utilities for AutoCAD, Inventor and other Autodesk products [www.cadforum.cz]
  Visitors: 7200
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedDelete Layouts in multiple dwgs&change viewport la
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: Delete Layouts in multiple dwgs&change viewport la
    Posted: 04.Jun.2018 at 11:44
FYI - Viewports do not have to be located on the Defpoints layer in order not to be printed.  Merely create a layer called VPorts and set it to "no print" (i.e. - red diagonal through printer symbol).
<<AutoCAD 2015>>
Back to Top
sonybabu View Drop Down
Newbie
Newbie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Posted: 04.Jun.2018 at 08:28
Hai,
We have some projects in which we have to print shop drawings prepared in tekla and MEP in autocad.
While exporting shop drawings from tekla to autocad, there are some issues, couple are mentioned below.
1. There are 3 Layouts in each shop drawings (Layout1, Layout2 and TSLayout) in which TSLayout only contains the shop drawings and xref files. I need to delete Layout1 & Layout2 and keep the TSLayout only.
2. Vieports are not in Defpoints, therefore while printing from AutoCAD viewports are also printed. Need to convert/change them to defpoints before printing.
There are more than 1000 shop drawings and I am looking for solutions related to these issues.Sample drawing is attached. Can anyone help ?Confused
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,379 seconds.
