CZ | EN | DE
Login or
registration
  Visitors: 4489
RSS discussions
Discussion Discussion forum
HelpCAD discussion
Topic ClosedDraftsight - Ghost Line
 Post Reply Post Reply
Author
DrawCADJim View Drop Down
Newbie
Newbie
Using: AutoCAD2009, Draftsight
Status: Offline
Direct Link To This Post Topic: Draftsight - Ghost Line
    Posted: 05.Jul.2018 at 11:53
Hi, can anyone help me with how to start some geometry at a set distance from another point in Draftsight? I think this was using a 'Ghost Line' in AutoCAD.
I'd like to use this function all the time to prevent leaving unwanted geometry on drawings which can cause issues.
Apologies if I'm in the wrong place or you don't really cover Draftsight.
Thanks
Jim
Thanks
Jim
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 05.Jul.2018 at 23:17
Hello DrawCADJim, I don't realy use Draftsight but as it's a clone of AutoCAD you should try the same commands as with AutoCAD.
To start a geometry with lines try the command LINE and clic for the first point then add a distance with numbers and see...
There should be also ARC, CIRCLE, etc...
I have noticed a lot of commands with the same name.
In fact we did use Draftsight to "lower" AutoCAD files from an upper release to our release and then switch dirrectly to our AutoCAD so...
There is an official documentation about Draftsight.
Edited by philippe JOSEPH - 05.Jul.2018 at 23:17
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Jul.2018 at 11:11
Perhaps you are referring to the FROM (command modifier) which could be used to specify a temporary reference or base point from which the user can specify an offset to locate the next point to start a line?
As far as I know there was no "Ghost line" command in AutoCAD.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 07.Jul.2018 at 07:09
Gost lines = construction lines ?
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 07.Jul.2018 at 13:16
Then look at XLINES (AutoCAD) or their equivalent in Draftsight.  I think it is called INFINITELINE.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,414 seconds.
