RSS discussions
Discussion Discussion forum
Topic Closeddrill control
 Post Reply Post Reply
Author
ckemps View Drop Down
Newbie
Newbie
Using: autocad2023
Status: Offline
Direct Link To This Post Topic: drill control
    Posted: 05.Sep.2025 at 13:11
I have a template drawing that contains a band object. This band consists of several blocks with text inside. I would like to make the entire band 5 times larger, including the text.
When I try to scale the whole band at once, the software only scales the geometry but keeps the original text size defined in the blocks. So the text does not get scaled up.
What I need is for both the geometry and the text inside the blocks to be scaled up by a factor of 5. Does anyone know how I can achieve this?
Back to Top
julecave View Drop Down
Groupie
Groupie
Using: audocad 2015
Status: Offline
Direct Link To This Post Posted: 26.Nov.2025 at 18:26
No good player is saying drill is weak, only the evo is
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 27.Nov.2025 at 09:36
Hello ckemps, please send the or a file including one of those blocks so that we can take a look but if included in a block all elements should be scaled, rotated, copied, etc..
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 01.Dec.2025 at 14:46
What is the Text?  It sounds like it may be annotative Attributes.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,205 seconds.
