Please abide by the
rules of this forum.
Viewport Rotation
Author
Topic Search Topic Options
Prasanna Achar
Newbie
Using: Autocad2008
Status: Offline
Topic: Viewport Rotation Posted: 14.Apr.2011 at 07:32
How to rotate images in a viewport in layout tab without rotating objects in model tab?
Thanks in advance..
eskimo_lee
Newbie
Using: AutoCAD 2011
Status: Offline
Posted: 14.Apr.2011 at 10:26
All you have to do is Rotate like you do with objects in the model space.
Click on the view port so it is highlighted with the grips click the rotate button or type the command and then rotate as normal.
I hope this was helpful.
cheers,
eskimo_lee
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 14.Apr.2011 at 11:45
I do not agree with eskimo_lee's advice.
See this link:
"Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance." <<AutoCAD 2015>>
Prasanna Achar
Newbie
Using: Autocad2008
Status: Offline
Posted: 14.Apr.2011 at 12:13
Thanks for response. I had got solution from cad forum itself.
Thanks John..
Flip2011
Newbie
Using: Autocad 2008
Status: Offline
Posted: 18.Apr.2011 at 11:33
Guys please assist because this does not apply as he is a Auto-Cad 2008 user and none of those tips work! I have 2008 Lt and neither works for me, so i doubt it would help him.
Flip
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 18.Apr.2011 at 12:02
The advice does apply to full AutoCAD. The DView command, with Twist option, should work in LT. Edited by John Connor - 18.Apr.2011 at 12:07
dabrovsky
Groupie
Status: Offline
Posted: 18.Apr.2011 at 12:29
hi there,
you need to set UCS align with you angle (within you view port)
then type "plan" enter then type "c" for current
it will work,I am 100% sure
good luck
Forum Jump
-- Select Forum --
-CAD Forum- (read-only)
AutoCAD
Inventor
Revit
Civil 3D, Map, InfraWorks
Fusion 360
3ds Max, Maya, VRED
CAD - general
ARKANCE (CAD Studio) applications
RSS Feeds
Technical support by ARKANCE
Forum Permissions You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum
This page was generated in 0,079 seconds.
