RSS discussions
Discussion Discussion forum
Topic ClosedHelp: Creating Working Profile
 Post Reply Post Reply
Author
rclaxton View Drop Down
Newbie
Newbie
Using: autocad 2012
Status: Offline
Direct Link To This Post Topic: Help: Creating Working Profile
    Posted: 29.Feb.2012 at 22:26
I am trying to set a profile up so that it has all the default layers that I normally work with as well as the dimension styles that I have set up and different text sizes.
This would really save me a lot of work rather then going through and setting it up differently for each drawing have a list of defaults to choose from.
Any help would be appreciated.
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 29.Feb.2012 at 23:02
First, and foremost, it's not a "profile" you're after, it's a drawing template.  A DWT file.
Start a new drawing.  Include all of the text, dimension, mleader, and table styles you normally use.  Add in all the layers you want as standard, along with their colors and linetypes and weights.  If you want a title block or several on layout tabs make them too.  Basically build your entire drawing... the one you want to always start from... and then Save As a DWT.
Over time return to it and make corrections and/or additions as you need to.  If you want to always start new drawings using this template, set it up as your QNEW in Options > Files.
Dave
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Mar.2012 at 11:13
I agree with heinsite.  You need to create a custom template.
Re: Profiles.  A Profile holds settings for user preferred options such as:
Support file search paths
User preferences like right-click customizations
User selection options such as pick box and grip sizes
Interface elements like drop-down menus, toolbars, palettes, etc.
Profiles store the drawing environment settings (i.e. - what you see on your screen).  These settings can be accessed via the Options dialog box.
Profiles can be saved, exported and imported.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad 2012
Status: Offline
Direct Link To This Post Posted: 01.Mar.2012 at 14:30
Perfect I new it must be something simple. thanks for the response.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 01.Mar.2012 at 22:14
I never said it was going to be "simple".
LOL
Dave
Dave Hein, P.E.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,156 seconds.
