RSS discussions
Discussion Discussion forum
Topic ClosedNew Variable for Wipeout Frames
 Post Reply Post Reply
Author
LTunlimited RSS View Drop Down
RSS robots
RSS robots
Status: Offline
Direct Link To This Post Topic: New Variable for Wipeout Frames
    Posted: 16.Aug.2012 at 08:57
If you regularly use wipeout objects in your drawings, you’re probably familiar with the longstanding dilemma: Frames on or off? If a wipeout’s frame is on, you can edit its shape, but it will also plot—possibly defeating the point of having a wipeout in the first place. If the frame is off, it won’t plot, but it’s a lot harder to see & select if you need to. In AutoCAD LT 2013, this dilemma has been removed, because wipeouts have joined the cast of objects (like images) that can have visible, non-plotting frames. Simply set the new system variable WIPEOUTFRAME to 2, or use the Frames option inside the Wipeout command itself.
Go to the original post...
LT Unlimited - Autodesk blog by Kate Morrical
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,074 seconds.
