RSS discussions
Discussion Discussion forum
Topic ClosedAnsi B18.6 (Phillips Head)
 Post Reply Post Reply
Author
JRob View Drop Down
Groupie
Groupie
Using: Acad2000
Status: Offline
Direct Link To This Post Topic: Ansi B18.6 (Phillips Head)
    Posted: 25.Apr.2013 at 01:35
I looking for dimensions for a Phillips Head screw.  I found slot length, width, and depth.  But I could not find included angle.  Does anyone have theses dimension or better yet a drawing for a #2 Phillips Head.
Joe  Smile
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Apr.2013 at 11:38
It begs the question as to why you are even drawing a screw when there are entire symbol (block) libraries of screws and bolts available?
80-82 degrees.
Edited by John Connor - 25.Apr.2013 at 11:51
<<AutoCAD 2015>>
Back to Top
JRob View Drop Down
Groupie
Groupie
Using: Acad2000
Status: Offline
Direct Link To This Post Posted: 30.Apr.2013 at 21:55
John Connor,
Thanks for your response.  Basically, I drawing phillips head screws as a brain teasers while I recover from By-pass surgery.  I tried finding 3d phillips head screws in the Cad forum search and google search, but didn't have much luck.  The only download I found was incompatible with AutoCad 2000.  If you are aware of a good link I would much appreciate your passing on the link for the web site or download.  Any other reviewers who would like to comment are more than welcome!!
Joe
WinkConfused
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.May.2013 at 11:41
Are you doing this in 2D or 3D?
I gave you the angle.  You have the other information.  What more do you need?
Edited by John Connor - 01.May.2013 at 11:42
<<AutoCAD 2015>>
Back to Top
JRob View Drop Down
Groupie
Groupie
Using: Acad2000
Status: Offline
Direct Link To This Post Posted: 01.May.2013 at 19:25
John Conner
Thanks again for your reply.  I'm trying to draw in 3D and I am fairly new to AutoCad 3D.  I'm not questioning you answer of 80-82 degrees for the included angle. But when I draw the slot width and depth, the 80-82 degree angle cuts off the bottom of the depth.  So, I'm doing something wrong, or some of the information (dimensions) I'm using are incorrect.  Any additional input from you would be appreciated.
Joe Ouch
Back to Top
JRob View Drop Down
Groupie
Groupie
Using: Acad2000
Status: Offline
Direct Link To This Post Posted: 06.May.2013 at 01:03
I'm still looking for dimensions for a #2 Phillips Head slot.  John Conner supplied 82 deg. as the included angle.  I just notice that 82 deg. is the included angle for "flat head" screw, not the included angle for #2 Phillips Head slot.  Does anyone have dimension for the slot (particularly the included angle).  Or does anyone have a link to downloads for 3D screws. Your response is always appreciated. JRob
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.May.2013 at 11:45
I gave you a range of 80-82.
Here's an idea.  Find H.F. Phillips' patent (No. US2046837) and check to see if the angle is mentioned in the Overview, Abstract, Drawings or Description.  Have you never done basic research?  Or....get a screw and measure it yourself.
Edited by John Connor - 06.May.2013 at 12:01
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,090 seconds.
