RSS discussions
Discussion Discussion forum
Topic Closedbit maps on 3d models
 Post Reply Post Reply Page  <12
Author
Cad64 View Drop Down
Senior Member
Senior Member
Using: Autocad 2011, 3DS Max 2011, Photoshop CS5
Status: Offline
Direct Link To This Post Posted: 27.Mar.2011 at 01:48
Ok, that's fine but you don't need to complicate things by trying to use the direct X shader. It's not necessary. Just create your texture normally. Put your bitmap in the "Diffuse" slot and then in the "Bump" slot, choose "Normal Bump" and then add your normal map there.
Online Portfolio: http://www.rdeweese.com/
Back to Top
rendermen View Drop Down
Groupie
Groupie
Using: 3ds max design
Status: Offline
Direct Link To This Post Posted: 27.Mar.2011 at 14:21
Sorry to be a pain. I assigned a diffuse map to Diffuse Color and my Nvidia normal blue map to bump. i do not get the realistic result I was getting. I see no and bump effect. Even if i turn up the amount or off and on toggle I see no differences.
Renderman
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 27.Mar.2011 at 15:09
I think I see the problem. I can see my result in F9 render only. Otherwise I do not see it even though I have show maps checked. I do have an inexpensive video card, I wonder if that is some of my problems.
Renderman
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 27.Mar.2011 at 15:36
I can see the bump affect in the thumbnail however not on the model. Only if I render it.
When i used the direct shader no problems seeing the bump on the model I just could not change the scale.
Renderman
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 27.Mar.2011 at 16:19
So you want to see the effect in the viewport? I don't really see the point of that. The whole point of using maps to create detail is so you don't have to deal with it eating up resources and bogging down your system. The detail is generated during rendering.
The direct x shader is for game developers so they can see how their materials will look in the game as they animate their characters and move them around in the viewport. It's not really for people doing still renders of a house. I've never used it myself, because I don't work in the game industry and therefore have no real use for it. If I want to see how something will look I will just do a quick render to check materials.
But, to each his own. If that's how you want to work, it's up to you.
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 27.Mar.2011 at 16:58
Very good point! I am new at 3ds and I don't even know what I want yet. ha. I see what you mean. Thanks a ton for your input! I may need to take a class because I sure am doing a lot of stumbling trying to figure things out.
Renderman
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 27.Mar.2011 at 18:51
That would probably be a good idea. Learning this program on your own is very difficult. I know because I did it. If you can't find a class, look online for training DVD's. There are lots of them out there.
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 27.Mar.2011 at 20:05
One area I thought I want to get in to would be remodeling work.  With Inventor I create the model, add a proposed addition, and make it look realistic with a walk through. I felt that I needed the cad model for other reasons. I also felt it would be easier drawing in cad which I already kind of know. If the customer makes a revision the update is so much easier with the parametric relationship. I was in hopes they talked to each other better then that. Did you get my email the other day? I could send you my house model if you had time to give me your opinion.
Renderman
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 27.Mar.2011 at 20:20
Autodesk only just recently added an import option for Inventor files in 2011 or 2010, but as far as the two programs talking to each other, I don't think that's possible.
If you're working in Autocad, you can reference your dwg file into Max with the "File Link Manager", much like an xref in Autocad. Any changes you make to the dwg file can then be updated in the Max file. But that functionality is not available for Inventor. Maybe in a future release?
I did not receive an email from you. Try sending it again. I could take a look at your model, but I'm not an architect. So if you're looking for design tips, I wouldn't really be able to give you much.
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 27.Mar.2011 at 20:41
I sent it to you RDxxxx address. The last one may have went in your junk or spam
Renderman
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,086 seconds.
