Print Page | Close Window
placing template
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7969
Printed Date: 09.Jun.2026 at 11:05
Topic: placing template
Posted By: designbo
Subject: placing template
Date Posted: 12.Jun.2012 at 15:38
Created a border of our company layout and have tried to place in paper space. When placing into paper space nothing shows up but square. Do I have to save this as a template file, place it in the template folder then try to insert into paper space??
have already saved it in dwt format and inserted into template file for transfer into paper space, but when placed nothing shows up
thanks..
andsly
Posted By: John Connor
Date Posted: 12.Jun.2012 at 19:06
Why would you create a template then try to insert it in another template?
When you OPEN a new drawing select your template; don't use the default template.
This "layout" as you call it must be your company title block and border right?
<<AutoCAD 2015>>
Posted By: heinsite
Date Posted: 12.Jun.2012 at 21:22
It's not clear how you did things, but here's how most of us accomplish this:
1.  In Model space, create a title block border to paper scale (22"x34", ANSI A, or whatever size paper you'll be plotting to) that includes all of your borders, and company information, etc.  Be sure to put the origin of this at 0,0 and allow for paper margins.
2.  Include all attributes you might want for repeatable information, such as dates, Drawn by, Checked by, etc.  Include any fields as well.
3.  Make this entire assembly a block.
4.  Now (!) go into the Layout space and Insert this block at 0,0.  Set up all the plot configurations you might use for it.
5.  Save this file as a Drawing Template (DWT).
From there as John notes, when you start a new drawing use this as your starting template file.
Remember also that this is MUCH more than just a title block template.  If (and you should!) you include standard layers in the file, Text, Dimension, Multileader, and Table styles in your setup, and other settings, they will also come along for the ride everytime you start a file with this DWT.
It's not important that you get it all right or everything included the first time.  But you should revisit it and update it frequently as you first start using it when you find things that are missing or need correction.  It's a process that will take a bit of time... but save you much more in the long run and lead to consistency in your work.
Good luck!
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Posted By: designbo
Date Posted: 13.Jun.2012 at 19:36
yes
andsly
Posted By: Breeze104
Date Posted: 13.Jun.2012 at 22:38
Big%20smileBig%20smile ClapClap  Thank you very much for this How-To.  I have been looking for this info for yrs and nobody has ever put it clearer.
I hadn't had to do a Title block this way since college (14yrs ago) and I wanted to start using the company title block in this format but was unable to find any do directions on how to do it.
KUDOS to heinsite
Thank you again!!!
Breeze
Posted By: rappelzdzd
Date Posted: 14.Jun.2012 at 04:13
What you said it is very interesting.
I heart which I could not help him
Posted By: designbo
Date Posted: 19.Jun.2012 at 20:00
I've tried this option several times and still it doesn't show up on plot configuration. Even made sure I wasn't in defpoint mode and still doesn't show up.. I followed directions exactly and still doesn't work...
andsly
Posted By: heinsite
Date Posted: 19.Jun.2012 at 20:40
It "... doesn't show up...", or you just can't see it?  There's a big difference.
In Layout/paper space do a Zoom Extents and see what happens.  Then a Ctrl-A to select everything.  Do you find any grips?  If not, then you haven't really inserted anything in paper space after all.
Beyond this you will need to be a little more descriptive about what you've done and what has happened.  Right now we're still guessing because it's not clear where you are in the process.
Dave.
Dave Hein, P.E.
Posted By: designbo
Date Posted: 20.Jun.2012 at 16:13
When I insert into paper space and configure plotter, preview shows nothing> I've made sure everything is layered properly and not on defpoints. The drawing shows as being there, but plot preview and plotting shows nothing....
andsly
Date Posted: 20.Jun.2012 at 18:00
Maybe whatever you inserted is so far off the mark that when you go to print it would obviously not show up.
Is there a titleblock and border in paper space already?
What are you inserting into paper space?
<<AutoCAD 2015>>
Posted By: designbo
Date Posted: 21.Jun.2012 at 18:26
inserting corner at 0,0 and it shows up on paper space. When I go to print nothing shows up....
andsly
Posted By: designbo
Date Posted: 23.Jun.2012 at 15:59
yes
andsly
Posted By: designbo
Date Posted: 26.Jun.2012 at 16:15
would it be helpful if I sent you the drawing?
andsly
Date Posted: 26.Jun.2012 at 18:16
Where are you actually located in the U.S.?
What is the best time to meet you on this forum?
I'm located in Connecticut.  My schedule varies but I usually check this site in the early morning.
I purposely have my email address blocked and only unblock it for people to email me something.  Then I reblock it immediately.
<<AutoCAD 2015>>
Posted By: designbo
Date Posted: 26.Jun.2012 at 21:17
Golf Mecca of the world Augusta Georgia
andsly
Date Posted: 27.Jun.2012 at 11:30
Well at least we're in the same time zone.
<<AutoCAD 2015>>
Posted By: designbo
Date Posted: 27.Jun.2012 at 14:46
Please visit our website www.sandgeng.net for info.
andsly
