Print Page | Close Window
Saving .rvt files Down to Older Version
Printed From: CAD Forum
Category: EN
Forum Name: Revit
Forum Description: Discussion about the BIM application Autodesk Revit (Architecture, Structure, MEP), Autodesk Forma
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8264
Printed Date: 10.Jun.2026 at 08:46
Topic: Saving .rvt files Down to Older Version
Posted By: mlacour
Subject: Saving .rvt files Down to Older Version
Date Posted: 17.Aug.2012 at 15:59
It is my understanding that I can not save a 2012 .rvt file down to
a 2010 .rvt file for one of our clients. How are multiple disciplins
using different versions of Revit getting around this??
Mike LaCour
Posted By: Vladimir Michl
Date Posted: 17.Aug.2012 at 16:01
They should be on the same version. You can use IFC to communicate Revit data (with some loss) between versions.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world" rel="nofollow - https://arkance.world - Autodesk Platinum Partner
Posted By: CRAWFORDROCKS
Date Posted: 06.Sep.2012 at 22:59
If They Only have 2010 then you should keep your old version of the 2010 and not open any of their stuff with your version.  You can still use PDF and like methods to show things but the versions are not compatible.  Once opened and saved in a newer version It will never be opened in the older version.  One way for them to say you have to update every year.  My firm is using 2013 and we cannot do anything with anyone around my area yet as everyone here is still in 2010 or 2011 or even still in acad.
"TO INFINITY AND BEYOND"
