Print Page | Close Window
problem on converting DWG ec120 model in iges
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8398
Printed Date: 09.Jun.2026 at 10:14
Topic: problem on converting DWG ec120 model in iges
Posted By: zoilgust
Subject: problem on converting DWG ec120 model in iges
Date Posted: 20.Sep.2012 at 09:20
Dear all,
I'm on a chopper project for my job and I need a ec120 cad model to work on.
I found it on this forum (many thanks) but it's in a DWG format and cannot be imported on catia v5 Cry
Is someone could transform it for me ?
in step or iges ?
just need the external skin or the entire model
many thanks in advance
jeremie
Posted By: philippe JOSEPH
Date Posted: 20.Sep.2012 at 09:53
Hello, is the "ec120" that your are talking about the helicopter_ec120_eurocopter.dwg drawn by Vladimir MICHL ?
If yes, then you will have to communicate with him because it's drawn with AutoCAD 2013 and I have only AutoCAD 2008.
On AutoCAD : Fichier, Exporter, Exporter des données --> ACIS (*.sat) or
Fichier, Exporter, IGES --> IGES Files (*.igs , *.iges).
Posted By: zoilgust
Date Posted: 20.Sep.2012 at 10:10
Thanks for your reply,
yes, it's vladimir's ec120.
I don't found where I can send him a private message, hope he will see this topic Smile
or if someone have autocad 2013 it will be great and very helpful if you can help me
jeremie
Posted By: Vladimir Michl
Date Posted: 20.Sep.2012 at 16:51
You can contact me as the webmaster - see the footer.
The IGES export has been too slow, but I have resaved the model (not drawn by me) to the DWG2000 file format. The The DWG2000-version of the this model is on: http://www.cadforum.cz/forum_en/uploads/Helicopter_EC120_Eurocopter0.zip - http://www.cadforum.cz/forum_en/uploads/Helicopter_EC120_Eurocopter0.zip
Vladimir Michl (moderator)
ARKANCE - https://arkance.world" rel="nofollow - https://arkance.world - Autodesk Platinum Partner
Posted By: zoilgust
Date Posted: 20.Sep.2012 at 17:44
Many thanks !!!
but I can't open it with catia V5 .... at work I haven't this license, only basics ones
I tried to open it with another program like google sketch up, it's ok, but IGES plugins cannot export surfaces .... strange for an iges plugin
Very hard this history ....
Any chance to try again to export an IGES from autocad with external surfaces only ?
It's already very nice that you wasted time for me .... if you can't no problem, I understand
thanks
jeremie
Date Posted: 21.Sep.2012 at 07:58
Hello zoildust and Vladimir, I have done an export to XXX.igs file but it's giving a 71 Mb file ( it didn't take too much time to do ).
How can I communicate it ?
When I did the export there was 8 panels of options to set and I choose to do it with the setings unchanged.
On the original DWG file I did scalelistdelall and the file was lowered by 1 Mb.
Here we have AutoCAD 2008, Solidworks 2008 and ProEngineer and I can confirm that the different exports can work or not and even can't be possible sometimes if the files are too big.
I am personally working on AutoCAD 2D and 3D and I'm using Solidworks basically as an interface between the 3 softwares.
To be continued...
Date Posted: 21.Sep.2012 at 08:34
Hello again, i have opened the file with AutoCAD and it looks like the model is based on surfaces and not volumes ( correct me if I'm wrong ).
May be that's why I only get a 2D sketch when I try to open it with Solidworks.
May be a big specialist could give us more informations or tips...
Posted By: zoilgust
Date Posted: 21.Sep.2012 at 10:16
many thanks for your help !!!! Clap
maybe a transfert with a free website like the closed megaupload ?
Date Posted: 21.Sep.2012 at 13:32
OK zoilgust, I will take a look.
Posted By: zoilgust
Date Posted: 21.Sep.2012 at 14:11
ok, or with http://dl.free.fr/ ?
Date Posted: 24.Sep.2012 at 08:41
Hello again, I'm back, I have made a ZIP of the IGS file and it's only 7.5 Mb.
If you give me an e-mail I can send it to you.
I have looked at FREE.fr and I would also have needed an e mail adress.....
Posted By: zoilgust
Date Posted: 24.Sep.2012 at 09:25
hi,
thanks again Tongue
here is my email :
zoilgust@sfr.fr
Posted By: isaacburrough
Date Posted: 14.Dec.2012 at 14:40
Hi
Is there any chance I could also get a copy of the iges file?
email address is isaacburrough@gmail.com
Isaac
