  právě nás čte: 7107
CAD tip CAD tip # 10277:
Přehled síťových kódů "Feature Code" pro produkty Autodesk 2016.
A - odpověď Pro autorizaci plovoucí síťové licence (NLM) na licenčním serveru FlexNet/FlexLM používá rodina Autodesk 2016 následující produktové kódy, tzv. "Feature Code":
Produkt Autodesk 2016 Feature Code
Autodesk 3ds Max 2016 864713DSMAX_2016_0F
Autodesk 3ds Max Entertainment Creation Suite Standard 2016 86464MXECS_2016_0F
Autodesk 3ds Max with SoftImage 2016 864733DSMXS_2016_0F
Autodesk Advance Concrete 2016 86515ADSTCP_2016_0F
Autodesk Advance Steel 2016 86507ADSTPR_2016_0F
Autodesk Advance Steel 2016 with AutoCAD 86506ASPACD_2016_0F
Autodesk Alias AutoStudio 2016 86427ALAUST_2016_0F
Autodesk Alias Concept 2016 86581ALSCPT_2016_0F
Autodesk Alias Design 2016 86428DESNST_2016_0F
Autodesk Alias SpeedForm 2016 86581ALSSF_2016_0F
Autodesk Alias Surface 2016 86429SURFST_2016_0F
Autodesk Alias TC Integrator for GM 2016 86430ATCIGM_2016_0F
Autodesk AutoCAD 2016 86445ACD_2016_0F
Autodesk AutoCAD 2016 for Mac 86511ACDMAC_2016_0F
Autodesk AutoCAD Architecture 2016 86480ARCHDESK_2016_0F
Autodesk AutoCAD Civil 3D 2016 86514CIV3D_2016_0F
Autodesk AutoCAD Design Suite Premium 2016 86444DSPRM_2016_0F
Autodesk AutoCAD Design Suite Standard 2016 86446DSSTD_2016_0F
Autodesk AutoCAD Design Suite Ultimate 2016 86432DSADV_2016_0F
Autodesk AutoCAD Electrical 2016 86481ACAD_E_2016_0F
Autodesk AutoCAD Inventor LT Suite 2016 86485INVLTS_2016_0F
Autodesk AutoCAD LT 2016 86447ACDLT_2016_0F
Autodesk AutoCAD LT 2016 Flexible License 86448ACLTNL_2016_0F
Autodesk AutoCAD LT 2016 for Mac 86512ACDLTM_2016_0F
Autodesk AutoCAD LT Civil Suite 2016 86513ACDLTC_2016_0F
Autodesk AutoCAD Map 3D 2016 86517MAP_2016_0F
Autodesk AutoCAD Mechanical 2016 86478AMECH_PP_2016_0F
Autodesk AutoCAD MEP 2016 86479BLDSYS_2016_0F
Autodesk AutoCAD P&ID 2016 86517PNID_2016_0F
Autodesk AutoCAD Plant 3D 2016 86517PLNT3D_2016_0F
Autodesk AutoCAD Raster Design 2016 86474ARDES_2016_0F
Autodesk AutoCAD Revit Architecture Suite 2016 86465REVITS_2016_0F
Autodesk AutoCAD Revit LT Suite 2016 86449RVTLTS_2016_0F
Autodesk AutoCAD Revit MEP Suite 2016 86466REVSYP_2016_0F
Autodesk AutoCAD Revit Structure Suite 2016 86467REVSU_2016_0F
Autodesk AutoCAD Utility Design 2016 86517UTLDESN_2016_0F
Autodesk Building Design Suite Premium 2016 86451BDSPRM_2016_0F
Autodesk Building Design Suite Standard 2016 86452BDSS_2016_0F
Autodesk Building Design Suite Ultimate 2016 86443BDSADV_2016_0F
Autodesk CFD 2016 86540SCFD_2016_0F
Autodesk CFD 2016 Advanced 86541SCFDA_2016_0F
Autodesk CFD 2016 Connection for NX 86543SCFDNX_2016_0F
Autodesk CFD 2016 Connection for Parasolid 86544SCFDP_2016_0F
Autodesk CFD 2016 Connection for Pro ENGINEER 86545SCPROE_2016_0F
Autodesk CFD 2016 Design Study Environment 86546SCDSE_2016_0F
Autodesk CFD 2016 Motion 86547SCFDM_2016_0F
Autodesk Display Cluster Module for Autodesk VRED Design 2016 86518DCMVRD_2016_0F
Autodesk Entertainment Creation Suite Ultimate 2016 86435ENCSU_2016_0F
Autodesk Fabrication CADmep 2016 86519CADMEP_2016_0F
Autodesk Fabrication CAMduct 2016 86520CAMDCT_2016_0F
Autodesk Fabrication CAMduct Components 2016 86521CAMLTE_2016_0F
Autodesk Fabrication ESTmep 2016 86522ESTMEP_2016_0F
Autodesk Fabrication RemoteEntry 2016 86523RMNTRY_2016_0F
Autodesk Fabrication Tracker 2016 86524TRCKIT_2016_0F
Autodesk Factory Design Suite Premium 2016 86475FDSPRM_2016_0F
Autodesk Factory Design Suite Standard 2016 86502FDSS_2016_0F
Autodesk Factory Design Suite Ultimate 2016 86476FDSADV_2016_0F
Autodesk Factory Design Utilities 2016 86491FDU_2016_0F
Autodesk GM CAD Convertors 2016 86436GMCADC_2016_0F
Autodesk Helius Composite 2016 86549ACMPDS_2016_0F
Autodesk Helius PFA 2016 86548ACMPAN_2016_0F
Autodesk HSMWorks Premium 2016 86525HSMPRM_2016_0F
Autodesk HSMWorks Professional 2016 86526HSMPRO_2016_0F
Autodesk Infrastructure Design Suite Premium 2016 86468IDSP_2016_0F
Autodesk Infrastructure Design Suite Standard 2016 86508IDSS_2016_0F
Autodesk Infrastructure Design Suite Ultimate 2016 86442IDSU_2016_0F
Autodesk InfraWorks 2016 86529INFMDR_2016_0F
Autodesk InfraWorks 360 - companion 2016 86530IW360C_2016_0F
Autodesk InfraWorks 360 2016 86531IW360P_2016_0F
Autodesk InfraWorks bundle – Roads & Highways 2016 86532IMRH_2016_0F
Autodesk Inventor 2016 86492INVNTOR_2016_0F
Autodesk Inventor Engineer-to-Order 2016 - Distribution 86593IETODIS_2016_0F
Autodesk Inventor Engineer-to-Order Series 2016 86503INVETO_2016_0F
Autodesk Inventor Engineer-to-Order Server 2016 86487INTSER_2016_0F
Autodesk Inventor HSM 2016 86493INVHSM_2016_0F
Autodesk Inventor HSM Pro 2016 86494INHSMP_2016_0F
Autodesk Inventor LT 2016 86496INVLT_2016_0F
Autodesk Inventor OEM 2016 86495INVOEM_2016_0F
Autodesk Inventor Professional 2016 86497INVPROSA_2016_0F
Autodesk Maya 2016 86437MAYA_2016_0F
Autodesk Maya Entertainment Creation Suite Standard 2016 86438MYECS_2016_0F
Autodesk Maya with SoftImage 2016 86441MAYAS_2016_0F
Autodesk Moldflow Adviser Premium 2016 86552MFAM_2016_0F
Autodesk Moldflow Adviser Standard 2016 86554MFAD_2016_0F
Autodesk Moldflow Adviser Ultimate 2016 86576MFAA_2016_0F
Autodesk Moldflow Design 2016 86550SIMDFM_2016_0F
Autodesk Moldflow Insight Premium 2016 86555MFIP_2016_0F
Autodesk Moldflow Insight Standard 2016 86556MFIB_2016_0F
Autodesk Moldflow Insight Ultimate 2016 86557MFIA_2016_0F
Autodesk Moldflow Synergy 2016 86558MFS_2016_0F
Autodesk MotionBuilder 2016 86460MOBPRO_2016_0F
Autodesk Mudbox 2016 86461MBXPRO_2016_0F
Autodesk Nastran 2016 86579NSTRN_2016_0F
Autodesk Nastran In-CAD 2016 86580NINCAD_2016_0F
Autodesk Navisworks Manage 2016 86534NAVMAN_2016_0F
Autodesk Navisworks Simulate 2016 86553NAVSIM_2016_0F
Autodesk Plant Design Suite Premium 2016 86469PDSPRM_2016_0F
Autodesk Plant Design Suite Standard 2016 86509PLTDSS_2016_0F
Autodesk Plant Design Suite Ultimate 2016 86470PDSADV_2016_0F
Autodesk Point Layout 2016 86535PNTLAY_2016_0F
Autodesk Product Design Suite Premium 2016 86477PDSP_2016_0F
Autodesk Product Design Suite Ultimate 2016 86462PDSU_2016_0F
Autodesk Raytracing Cluster Module for Autodesk VRED 2016 86537RCMVRD_2016_0F
Autodesk ReCap 2016 86538RECAP_2016_0F
Autodesk Revit 2016 86453RVT_2016_0F
Autodesk Revit Architecture 2016 86454REVIT_2016_0F
Autodesk Revit Engineer-to-Order 2016 - Distribution Package 86589RETODP_2016_0F
Autodesk Revit LT 2016 86455RVTLT_2016_0F
Autodesk Revit MEP 2016 86456RVTMPB_2016_0F
Autodesk Revit Structure 2016 86457REVITST_2016_0F
Autodesk Robot Structural Analysis Professional 2016 86439RSAPRO_2016_0F
Autodesk Showcase 2016 86582SHOWCASE_2016_0F
Autodesk Showcase Professional 2016 86539SHOWPRO_2016_0F
Autodesk Simulation CFD 2016 Connection for ACIS 86542SCACIS_2016_0F
Autodesk Simulation Mechanical 2016 86551ASMES_2016_0F
Autodesk SketchBook Pro 2016 86440SBPNL_2016_0F
Autodesk Studio Wall 2016 86595STUWAL_2016_0F
Autodesk T-Splines Plug-in for Rhino 2016 86561TSPRHN_2016_0F
Autodesk Vault Office 2016 86562PCOFFI_2016_0F
Autodesk Vault Professional 2016 86563VLTM_2016_0F
Autodesk Vault Workgroup 2016 86564VLTWG_2016_0F
Autodesk Vehicle Tracking 2016 86565VEHTRK_2016_0F
Autodesk VRED 2016 86516ADKVRD_2016_0F
Autodesk VRED Design 2016 86566VRDDES_2016_0F
Autodesk VRED Presenter 2016 86567VRDPRS_2016_0F
Autodesk VRED Professional 2016 86568VRDPRO_2016_0F
Autodesk VRED Server 2016 86572VRDSRV_2016_0F
CADdoctor for Autodesk Simulation 2016 86515MFCD_2016_0F
Enterprise Multi-Flex Enhanced Bundle 2016 86569EMFEB_2016_0F
mental ray Standalone 2016 86459MRSTND_2016_0F
T1 Enterprise Multi-flex 2016 86571T1MF_2016_0F
T1 Enterprise Multi-flex Prior Version 2016 86573T1MFPV_2016_0F
T1 Enterprise Multi-flex Standard Bundle 2016 86575T1MFSB_2016_0F
T1 Enterprise Multi-Flex Standard Prior Version Bundle 2016 86574T1MFPB_2016_0F
ACAD2016ADT2016Civil2016Plant2016Revit2016Inv2016max2016
15.4.2015    2985×
autocad civil inventor licence mapa office revit rodina vault
