  právě nás čte: 12901
CAD tip CAD tip # 898:
Jak nastavit volby pro rendering z LISPu nebo z makra?
A - odpověď Můžete využít LISPovské funkce RPREF "ROPT":
(c:rpref "ropt" STYPE ALIAS RSRVD TSAMP MINB MAXB
  TOSSBACK BACKNORM RAYDEPTH)
STYPE= "ascan" or "aray"
ALIAS= 1 NHNV
2 AHNV
3 AHSV (2x2)
4 AHSV3 (3x3)
5 AHSV4 (4x4)
RSRVD= 0 !MUST be zero
TSAMP= 1 Point
2 Linear
3 Mip map
MINB= real !Shadow map min bias
MAXB= real !Shadow map max bias
TOSSBACK= 0 FALSE !Off
1 TRUE !On
BACKNORM= 0 FALSE !Off
1 TRUE !On
RAYDEPTH= int !Number of bounces a ray can take
BUGS:
You must turn off the Render Information Dialog while using this API.
Bringing up the Rendering Information or
Rendering Preferences dialogresets these values
to their database values if a rPlus renderer is
the current renderer.
Calling the API will set all values except
RAYDEPTH which is set only if STYPE == "ARAY".
EXAMPLES:
(c:rpref "TOGGLE" "SKIPRDLG" "OFF") !Turn off Rend Info Dlg
(c:rpref "ROPT" "ARAY" 2 0 2 2.0 4.0 0 1 3) !Defaults, raydepth set
(c:rpref "ROPT" "ASCAN" 2 0 2 2.0 4.0 0 1 3) !Defaults, raydepth not set
(c:rpref "ROPT" "ASCAN" 2 NIL 2 NIL NIL 0 1 3) !Shows values skipped
(c:rpref "ROPT" "ARAY" 2 NIL 2) !Shows values skipped & quick end
[automatizace dávka dávkový script skriptování]
ACAD
11.1.2001    3989×
dialog mapa render
Ceny - CAD eShop:
platí pro: AutoCAD ·
