  Visitors: 4554
CAD tip CAD tip # 8012:
"Paper size not found" error.
A - answer When trying to PLOT a drawing, AutoCAD displays an error message: "The plotter configuration does not support the paper size of the current layout. What do you want to do?"
You are probably using a wrong print definition file .PC3 or its associated .PMP file. Either the file was copied from a different computer, from a different AutoCAD version, or it is pointing to a different printer driver. Try to re-create the PC3 file (and/or PMP).
ACAD
31.5.2011    5834×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 10759:How to publish a DWG to a PDF file without attaching "-Model" to its name?
Tip 10556:AutoCAD 2015 and 2016 do not allow to select paper size for Designjet T120/T520.
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Tip 10301:How to export PDF with hyperlinks from AutoCAD?
Tip 10182:How to create a PDF file from DWG without AutoCAD?
Track your time spent working on AutoCAD or Revit jobs - automatically with
CADstudio JobTime More info
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
