  Visitors: 4736
CAD tip CAD tip # 7935:
2D and 3D area of a terrain surface.
A - answer To measure an area of a 3D terrain surface in AutoCAD Civil 3D you can use the properties of the Surface object.
In the project Prospector, right-click on the selected surface and choose "Surface Properties" from the context menu. Switch to the Extended tab and expand the tree Extended. Here you will find the values for "2D Surface Area" (projected) and "3D Surface Area" (3D).
Surface (CZ version)
Civil
26.4.2011    19264×
Prices - CAD eShop:
applies to: Civil 3D ·
Tip 13163:Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD)
Tip 13040:iLogic - display information about complexity of an Inventor part.
Tip 12749:Generate parametric mathematical 3D surfaces (meshes) in Fusion 360.
Tip 11946:How to find net surface area (sans holes) of an unfolded sheetmetal part in Fusion 360?
Tip 11654:Select 3D solids by their height, volume, surface (smaller then...)
