  Visitors: 8661
CAD tip CAD tip # 11234:
3D relief on model surface in Autodesk Fusion 360.
A - answer The following videotips illustrate how you can use text or any sketch to create a 3D relief (emboss, engrave, pulled) wrapped on any surface of a 3D model in Autodesk Fusion 360.
Option 1 - pulled:
Option 2 - extruded to offset surface:
And a comparison of both options:
An interactive 3D model from Option 1: a360.co/2iHnyYX and block 13887
An interactive 3D model from Option 2: a360.co/2iH4Q3L and block 13886
The engraved wrapped text can be directly processed in Fusion's CAM CAM functions to create NC code for milling.
Fusion360
100% *  CAD,CAM
1.1.2017    7241×
Prices - CAD eShop:
applies to: Fusion 360 360 ·
Tip 12411:How to wrap text on a cylinder or a general 3D surface in Fusion 360?
Tip 7553:Emboss/engrave text on an Inventor 3D part.
Tip 7034:Cable braiding, ropes and other materials in Inventor.
Tip 2181:How to draw text in Braille script.
