  Visitors: 13198
CAD tip CAD tip # 9447:
ActiveX Server returned an error: Error loading type library/DLL
A - answer When you see this error message when running a LISP add-on application in AutoCAD, it may either indicate a programming error, or an installation error.
It may indicate a missing or corrupted file acad.tlb - which is a standard part of AutoCAD installation. Please check this file, it may be blocked by insufficient access rights or anti-virus during installation. You may need to perform a repair installation.
ACAD
16.9.2013    12690×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 12131:Error: no function definition: VLAX-ENAME->VLA-OBJECT or VLAX-VLA-OBJECT->ENAME
Tip 9369:Viewing 3D models from Navisworks in PowerPoint presentations.
Tip 8543:Setting command line background color from LISP.
Tip 7840:What are the differences between AutoLISP and VisualLISP?
