CAD tip # 7226:
applies to: AutoCAD · |
Tip 13948: | Undocumented function for quick block attribute editing - directly edit an attribute. |
Tip 13855: | DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder. |
Tip 13784: | Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT? |
Tip 13604: | Importing points from a Shape file as symbols/blocks mapped to object data. |
Tip 13599: | How to read iProperties from Inventor models and drawings in AutoCAD DWGs? |
Failed previews and downloaded documents in iProject. « | » What for are the WDL, WDR, WDD, WDW files in AutoCAD?
