  Visitors: 6434
CAD tip CAD tip # 7219:
Aligning drawings to multiple points (4, 5, 6 ...)
A - answer Besides the standard AutoCAD function for 3-point alignment of a drawing to the specified geometry - the ALIGN command - you can also use more advanced alignment methods in mapping and aligning the vector geometry of maps.
The alignment to 4, 5, 6 and more points (the pairs of source-target points) can be easily accomplished with the function ADERSHEET (rubbersheet; Tools > Map Edit) in AutoCAD Map 3D and AutoCAD Civil 3D. In this command, you enter the requested number of source and target points, select the transformed entities and the program performs the requested alignment (a non-linear transformation).
Warning - due to the approximation of the results (coordinates), the precision of the original geometry may be lost. Always align geometry drawn the same scale as the target drawing.
MapCivil
14.2.2010    25176×
Prices - CAD eShop:
applies to: AutoCAD Map 3D · Civil 3D ·
Tip 14017:Voronoi diagrams in AutoCAD.
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13495:How to create a full diameter dimension with two arrows?
Tip 13152:Compatibility of Autodesk products with Windows 11.
Tip 13095:How to change material texture orientation in Fusion 360?
