  Visitors: 5070
CAD tip CAD tip # 7641:
AutoCAD 2011 grip-stretch and osnap PER.
A - answer Grip-editing of LINE endpoints works differently in AutoCAD 2011 ("as designed"). You cannot e.g. use the PERpendicular osnap to move (stretch) the endpoint to a perpendicular point on another LINE. This works fine in AutoCAD 2010 (and older) but also on PLINEs in AutoCAD 2011.
As a workaround, you can use the standard STRETCH command to move the endpoint. But the STRETCH command requires a rather complicated window-crossing selection of the endpoint. To make things more efficient, you can now use our small AutoLISP utility - gStretch (see Download). Load it into AutoCAD, start the GSTRETCH command and just pick the line endpoint. You can move it to any position using any osnap.
ACAD2011LT2011
12.11.2010    9534×
Prices - CAD eShop:
applies to: AutoCAD 2011 · AutoCAD LT 2011 ·
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13688:How to select all DWG objects of a certain type in AutoCAD LT? (texts, circles...)
Tip 12755:How to create a polyline with multi-colored segments?
Tip 12501:Dynamic associative array of elements along a curve.
Tip 12172:How to show or hide an object in all visibility states?
