  Visitors: 9063
CAD tip CAD tip # 8263:
AutoCAD Civil 3D does not display the surface tooltip bubble.
A - answer AutoCAD Civil 3D 2012 does not show the info tooltip with elevation data of the surface "under" the cursor.
Please check the setting of the TOOLTIPS variable. This may be also caused by a collision with another application - e.g. the AVG antivirus, or the raster add-on Raster Design 2012. Try to use the _CUILOAD command to unload the ribbon AUTOCADRASTERDESIGN temporarily.
Civil2012CO2012
14.10.2011    11939×
Prices - CAD eShop:
Tip 12201:Quick dynamic measuring of objects near your cursor.
Tip 11599:Display object properties when hovering mouse cursor (rollover).
Tip 8367:Green corners around drawing views in Inventor.
Tip 8185:AutoCAD ecscad 2012 does not display tooltips.
Tip 7770:Cannot use Alt+nnn keyboard shortcuts in AutoCAD.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
