  Visitors: 4906
CAD tip CAD tip # 11063:
AutoCAD installation prompts to "Insert Disc 1".
A - answer When you download the AutoCAD installation image on a flash (USB) disc and install it from this removable media, the setup process may pause with the message "Insert AutoCAD Disc 1".
Your external USB device probably does not handle some OS disk functions properly. In this case, copy the installation files to a temporary folder on your hard disk and retry the installation from this drive. You can also use the option "Install Now" from your Autodesk Account.
An alternative option (for advanced users) is adding an option to the SETUP.INI file (on your USB media) via Notepad. To the section [SETUP] add a line with the parameter USE_REMOVABLE_DRIVE=YES - i.e:
[SETUP]
ACADLTACADM
24.8.2016    22368×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT · AutoCAD Mechanical ·
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
Tip 13513:How to quickly record a video from a CAD application or other Windows program? (replacing Screencast)
Tip 13192:Why I cannot see the "My Insights" tips and hints in AutoCAD?
Tip 12442:Non-modal (permanent) iProperties window in Inventor - SelectionInfo.
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
