  Visitors: 9346
CAD tip CAD tip # 11508:
AutoCAD problem in Windows 10 Anniversary update (F8 key)
A - answer After you install the Win10 "Anniversary Update" (update 1511), problems may start to appear in some case when working in AutoCAD 2017 or 2016 - e.g. some function keys do not work (F8 - ortho, and other) freezing AutoCAD, or the AutoCAD 2016 license activation fails when using the new Edge web browser version.
In this case (until a fix is available by Microsoft or Autodesk - UPDATE: install hotfix for AutoCAD 2016/2017/2018 - see below) you may want to return the Windows installation to its original state, before the anniversary update.
If you need to keep the anniversary update or if it cannot be reverted anymore (>10 days), you may fix the broken function keys by setting the TEMPOVERRIDES variable to 0.
This problem has been fixed in the hotfixes 2018.0.1, 2017.1.1 or 2016.0.10 (and higher, e.g. 2018.1).
ACAD2018ACAD2017ACAD2016
100% Win10  CAD
1.7.2017    9720×
Prices - CAD eShop:
applies to: AutoCAD 2018 · AutoCAD 2017 · AutoCAD 2016 ·
Tip 13513:How to quickly record a video from a CAD application or other Windows program? (replacing Screencast)
Tip 12900:When attempting to print, my PC fails to BSOD with APC_INDEX_MISMATCH
Tip 12867:Record anything in Windows 10 to a MP4 video.
Tip 12412:Missing category icons and thumbnails in Inventor Content Center.
Tip 12117:The Ctrl+Shift+letter hotkeys do not work (e.g. Ctrl+Shift+C in AutoCAD)
VRMLout More info
