CAD tip # 6928:
applies to: AutoCAD · |
Tip 13683: | Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for |
Tip 12131: | Error: no function definition: VLAX-ENAME->VLA-OBJECT or VLAX-VLA-OBJECT->ENAME |
Tip 11996: | How to rotate selected blocks by the angle of an existing block? |
Tip 11017: | How to select a DWG object by its internal ID, its "handle"? |
Tip 10636: | The entity isn't planar to the World Coordinate System and can't be converted. |
How to schedule areas of non-closed spaces in Revit?
