  Visitors: 10013
CAD tip CAD tip # 10408:
Autodesk Application Manager reports it has been retired.
A - answer When attempting to display updates of Autodesk products in the Application Manager window through the Windows taskbar, the application Windows shows the warning "This version of Application Manager hes been retired" and that it cannot be used to access Autodesk servers.
You are probably using an older version of this system component (V4.0.69.0 or older), where an automatic update has failed. Uninstall your Application Manager with Windows Control Panels and install a newer version (5.0.142 or higher) downloaded from Download.
ACAD2016ACAD2015Inv2016Inv2015Revit2016Revit2015
16.7.2015    6260×
Tip 13505:How to find which version of Inventor has saved a file?
Tip 13334:How to recover forgotten login password on the Holixa Licensor?
Tip 13192:Why I cannot see the "My Insights" tips and hints in AutoCAD?
Tip 12406:How to log out automatically from your Autodesk account after closing an app?
Tip 12306:How to check if a specific application or process is running?
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
