  Visitors: 7040
CAD tip CAD tip # 10996:
Autodesk Fabrication templates - JOT files.
A - answer
Using template files in Autodesk Fabrication, you can store all your usual program settings for everyday use - e.g. database settings, library parts, tables, reports, etc.
You can create the template when saving your job file, by choosing the filetype: Template(*.JOT) (instead of .MAJ or .ESJ).
Fabrication
6.7.2016    5790×
Prices - CAD eShop:
applies to: Fabrication ·
Tip 13996:Automatic hide for Revit palettes - save screen space (undocumented).
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13266:Where can I find the MAKEPAT command in Fabrication CAMduct?
Tip 11374:How to disable the Welcome screen in Fabrication CAMduct?
Tip 10923:Which Autodesk products do support the IFC format?
