  Visitors: 8952
CAD tip CAD tip # 10161:
Automatic checking of design limits in Inventor.
A - answer Since many versions back (R11), Inventor and Inventor LT contain a useful function for automatic checking of design limits in parametric models - AutoLimits.
If your ribbon (Inspect > AutoLimits) does not show the AutoLimits tab, check loading of the module "Automatic Limits" in the dialog Tools > Options > Add-ins:
With the AutoLimits function, you can add a number check-functions (points) to your model. These points will automatically watch any exceeding of the user preset limits - either geometrical (length, distance, angle, diamater, minimum distance, area, perimeter, volume), or physical (mass).
E.g. in this model, the limit-checks were added for lowest- and highest-possibler mass (the center point) and limits for radius on the leading edge of the propeller blade:
If you exceed these limts by editing the model parameters or geometry, the AutoLimits function will warn you by displaying a warning (yellow) or critical (red) icon.
The limits for the warning and alert range can be customized (in percentage or in absolute +/- values). You can also suppress displaying specific states (e.g. hide the "OK" status):
So you can easily check minimum required offset in assembly parts, impending collisions, electrical cross-talks, maximum mass or other design or manufacturing parameters in your models.
Inventor
13.1.2015    5726×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
Tip 13334:How to recover forgotten login password on the Holixa Licensor?
Tip 13211:Automatic numbering/renaming of multi-volume bodies in a part.
Tip 12766:Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge
Tip 12136:Security settings for Inventor data files and add-on applications.
VRMLout More info
