  Visitors: 9117
CAD tip CAD tip # 7944:
Automatic installation of AutoCAD 2012 add-on applications.
A - answer To simplify distribution of add-on modules (.NET, ARX, VisualLISP), AutoCAD 2012 (and higher) contains a new mechanism for easy automatic loading of applications and their menus (ribbons), including demand-loading (by typing a command from the respective application).
Application developers can distribute a specially formatted package ".bundle" containing all neccessary components of the given application, plus a XML control file PackageContents.xml. The structure of this XML file can be found in the documentation for developers (ADN).
The ".bundle" folder (e.g. "MyApplication.bundle") can be just copied as a subfolder to the folder:
C:\Program Files\Autodesk\ApplicationPlugins
(for all users) or to user-specific folders (in XP):
C:\Documents and Settings\{usrname}\Application Data\Autodesk\ApplicationPlugins
or (in Win7/Vista):
C:\Users\{usrname}\AppData\Roaming\Autodesk\ApplicationPlugins
The add-on application (here: "MyApplication") will be then loaded automatically. You can load such applications not only on launching AutoCAD, but also during a drawing session. Detecting ("sniffing") of the new/current status of the ".bundle" subfolders can be invoked manually, just by starting the APPAUTOLOADER command. This command loads any program modules, extends your AutoCAD menu and "teaches" your AutoCAD new functions and commands defined in the respective application.
The same command can also list all currently loaded ".bundle" modules. This autoloading mechanism is controlled by the APPAUTOLOAD variable.
ACAD2013ACAD2012
29.4.2011    11639×
Prices - CAD eShop:
applies to: AutoCAD 2013 · AutoCAD 2012 ·
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13887:ClosestPt - the nearest point on another curve
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13784:Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT?
Tip 13769:Connect points by a list of point numbers - PoNum.
