  Visitors: 8975
CAD tip CAD tip # 6724:
Automatically generated picture-legend of drawing blocks.
A - answer With the CADstudio BLegend utility you can easily create a legend (BOM table) of blocks used in your drawing (including icons - thumbnail previews of the blocks).
Load the LISP utility with APPLOAD and start it with the BLegend command. Since version 1.1 you can select block names and layers to include in the resulting table. Since version 1.2 you can schedule selected block references only. Then pick the top left corner of the legend table and specify its width. The legend will list all blocks in the current space (model/paper), their names, descriptions (see the block editor) and count. The legend is created in the current table style. You can then customize it (e.g. remove a column).
The labels are created in the current locale language (CZ/EN).
Generated block legend (in Czech) - picture-name-description-count
Legend (in Czech) created from the DWG block library Animals
You can download the free BLegend utility from Download.
Application dialog (in Czech)
ACAD2016ACAD2010ACAD2008ACAD2007ADTMapCivil
4.6.2009    31858×
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13784:Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT?
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13675:Two PURGE commands in Autodesk Civil 3D.
