  Visitors: 9613
CAD tip CAD tip # 8499:
Batch change of page setups and purging in DWG files.
A - answer AutoCAD 2012 (and higher) contains a new command "DWG format converter" (DWGCONVERT), this function is available also in the free viewer "Autodesk DWG TrueView". Besides the batch conversion of DWG file formats, it allows also batch error checking and repairs, batch setting of the default printer/plotter to "None", purging of drawings, binding xrefs, page setups, etc.
DWG Convert
The function for batch changing of page setups (plotting device) can be used in cases when you receive drawings from other users and when trying to plot them, you get a warning: "Printer name: This plotter configuration cannot be used for one of these reasons: the driver cannot be found, the device cannot be found, or the driver has a problem. The None plot device has been substituted."
This warning has to be always confirmed before the Plot dialog is displayed. By setting the plotter to "None" with DWGCONVERT you get rid of this message.
Procedure:
Start DWGCONVERT (in AutoCAD 2011 SAP or 2012 or use the latest free DWG TrueView), add DWG files to process, click on "Conversion Setups" to add/modify a new conversion batch. In the "Modify Conversion Setup" dialog choose e.g. the "in-place" conversion and check the option "Replace page setups" (the last one). Choose the source DWG file to copy the page setup from. Confirm the settings and run the batch conversion.
ACAD2014ACAD2012ACADLTDWG
28.2.2012    15217×
Prices - CAD eShop:
applies to: AutoCAD 2014 · AutoCAD 2012 · AutoCAD · AutoCAD LT · DWG ·
Tip 13847:Pringles in AutoCAD - a hyperbolic paraboloid.
Tip 13578:Change the block attribute type from variable to constant or vice versa.
Tip 13286:Markup assistant with intelligent character recognition.
Tip 13274:How to switch the DWG TrueView viewer to the classic user interface, without ribbon?
Tip 13228:DWG or DXF file exported to/from Fusion 360 has incorrect size (scale, 10x larger/smaller).
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
