  Visitors: 4058
CAD tip CAD tip # 8425:
Batch print for multiple drawings, multiple printers and copies.
A - answer One of the most requested tasks in an architectural or engineering office is a fast and convenient printout of multiple drawings at the same time, in a specified number of copies and paper formats, and possibly to multiple printers or plotters.
An advantageous method of such "super-batch-print" is using the CAD publishing format DWF (DWFx) with the free application Autodesk Design Review (see Download).
First you have to publish the individual drawings to the DWF format - you can do so from virtually any CAD software (incl. AutoCAD, Inventor and Revit), often you can do so automatically, during any standard save of the drawing file.
Once you have collected your DWF files, run the Design Review tool and from its application menu ("D-REV") choose Print > Batch Print Wizard:
Print Wizard
The Batch Print Wizard will lead you through the individual steps of the printing process. In the first step, choose your DWF and DWFX files, that should be batch-printed. Design Review will immediately show their size (format) and the number of sheets in each file:
List of files to be printed
In the next step, you can setup individual print parameters for each CAD file - you can direct them to a specific printer, choose the number of copies for each one, select the paper size (larger drawings will be tiled on smaller sheets), specify scale, color settings (only grayscale, black-and-white) and paper orientation:
Print parameters
You can finish the print wizard with the "Next" button and start printing with the "Print" button. Please note that the paremeters specified in the batch print wizard can be stored to a definition file .BPJ (batch print job) - you can easily repeat the same job in the future.
Wizard completed
You can also run a previously defined batch print job (by the BPJ file) directly from the Windows command line, using the command (example):
"C:\Program Files\Autodesk\Autodesk Design Review\DesignReview.exe" C:\Batches\MyFile.BPJ
resp.
"C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\DesignReview.exe" \ut\print1.BPJ
DWFACAD
19.1.2012    35873×   FAQ
Prices - CAD eShop:
applies to: DWF/Design Review · AutoCAD ·
Tip 11953:How to save PDF/A-1a archive from CAD software AutoCAD, Inventor, Revit?
Tip 11604:How to set plot transparency for all layouts in a DWG?
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Tip 9968:Batch conversion of CAD files from/to the IPT/IAM, STEP, IGES, SAT, Catia... formats
Tip 9147:Batch publishing to PDF uses different margins than single prints.
