CAD tip # 7214:
Tip 13311: | How to bulk transfer iLogic rules and forms from Inventor source documents? |
Tip 12837: | RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables |
Tip 12760: | Replace texts with blocks of the same name - Txt2Ref. |
Tip 12215: | How to change truecolor DWG objects to indexed ACI colors? |
Tip 12131: | Error: no function definition: VLAX-ENAME->VLA-OBJECT or VLAX-VLA-OBJECT->ENAME |
How to explode linetypes (to dashes)?
How to use 3DFACEs as a definition for terrain surface? (explode 3DFACE) « | » Editing selected segments of a polyline.
Featuring: Increase your productivity with our set of BIM add-on functions for Autodesk Revit CADstudio Revit Tools ![]() |
